You should be able to peel if off by starting with a plastic pry instrument and not scratching the paint. But having stated that, some dealers you various methods. Most are easy to pry or peal off.
Man that irks me. That's totally a midwest thing, or maybe east coast, but I would NEVER accept an advertisement on my vehicle other than the license plate frame, and thankfully that's all they try to do here on the west coast (Seattle).
Back in the midwest where I'm from (Saskatchewan) they put big banners on the back windows of pickup trucks... "ANOTHER INDIAN HEAD CHEVY TRUCK". You can remove them with a scraper but they're way over the top, I can't believe anyone accepts that kind of nonsense.
Nonetheless, if it's an actual emblem, likely dental floss is your best bet. The factory emblems come off quite easily with it at least.
I shake my head whenever I see people with cars that have the dealers name on their license plate frame! It's a lot like the following:
Sent from my iPhone
I see that all the time from iPhone users and I ask them "Why are you advertising for Apple? It's not like they're paying you for it". My sister does this all the time. Never removes it. Weird...
At least my dealer just uses vinyl lettering so it is easy to remove.
I can remember in the olden days when dealers actually drilled holes in the trunk lid and attached metal plates.
Heat gun, floss and Goo gone will do the trick. I hate dealer tags and made sure to ask them not to put it on. The dealer advised they don't put it on Vettes. They did put a dealer plate bracket on it, but that's a easier fix.
Set up a meeting with your attorney first and see what your legal options are before you use floss and a heat gun to remove it. You might have a strong enough case to put the dealership owner away for 25 to life and be awarded the entire dealership in court.
I wouldn't accept anything less than the death penalty.
Dealers up here in Ontario rarely put stickers or decals on the cars anymore, if they do anything at all it's just a licence plate frame, which is obviously very easy to remove.
