Red inserts on rims
Old Aug 7, 2017 | 04:44 PM
Miro's Avatar
Miro
Default Red inserts on rims
Hi guys, does anybody have any experience to install any color of rim inserts like on 2017 GS satin black rims with red lines, I am thinking to get stock glossy black rims and install some insert, but not vinyl tape, thanks for any input
Miro
Old Aug 7, 2017 | 08:50 PM
syswayne's Avatar
syswayne
Default need tool
My son and I did my 2016 C7 but you need the tool to do it for sure.
Old Aug 8, 2017 | 01:24 AM
Miro's Avatar
Miro
What kind of tool and where to get the product, would you mind to give me a link of any suppliers thank you so much
Old Aug 8, 2017 | 09:43 AM
Bob U's Avatar
Bob U
Did you use paint?
Old Aug 8, 2017 | 09:56 AM
Jacob's Avatar
Jacob
Miro
These are AlloyGators on OEM Z06 wheels, likely available from and installed by a local tire shop.
These are 1/8 inch red pinstripe tape on OEM Z06 wheels, available anywhere and DIY:
If anyone comes up with a paint machine for striping, I'm interested.
Jacob
Old Aug 8, 2017 | 10:55 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
The best I've seen is from tapeworks. They sell a tool that helps with installation. The op said no vinyl for some reason, so this wouldn't be good for him, but if you want color without protection or painting, tapeworks is the way to go.
Old Aug 8, 2017 | 12:21 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
I thought there things just clipped on to the end of the rim, you really need a tool for that?
Old Aug 8, 2017 | 06:37 PM
Bob Beroza's Avatar
Bob Beroza
I had RimBlades on my 2015 Arctic White Vette. After one year the glue started to let go from the red plastic RimBlade.
I like the look so much that I had to find an alternative. I purchased a set of Rim Ringz. The do not glue on they have small plastic clips built into the ring that hold it between the rim and the tire. They were easy to install and the company it absolutely GREAT to deal with.
Sorry for the bad angle view. But you get the idea.
Old Aug 8, 2017 | 06:59 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
From the pics on this thread, I like the tape better than the installed version. Looks to big for the tire and sticks out to far. Think I might do the tape and see how long it stays on.
Old Aug 8, 2017 | 07:43 PM
Blue666's's Avatar
Blue666's
Contact Rob at Tapeworks.com. He'll fix you up with the vinyl and his patented tool that gives you perfect results time after time
Old Aug 8, 2017 | 08:44 PM
teddycarnut's Avatar
teddycarnut
I used tapeworks a year ago on my GS holding up great and looks terrific, Tool helps buy is more money then the tape. I did mine without the tool with no problems. They give you 1 or 32 extra pieces to play with when you order the tape. Try that can always buy the tool afterwards if needed.
Old Aug 27, 2017 | 12:31 PM
HouseMouse's Avatar
HouseMouse
2nd Gear
I was wondering how it would look on wheels other than black. Would it look too goofy?
Old Aug 27, 2017 | 12:42 PM
Ramler's Avatar
Ramler
That car is gorgeous! Any mod other than ground effects would detract from the original beauty.
Old Aug 27, 2017 | 06:45 PM
Supersonic 427's Avatar
Supersonic 427
I originally used 1/8" 3M Red pin stripe tape about a month ago. However, I saw my friends Z06 painted red stripe at a car show and mine looked anemic! So, I had mine done from the same pin stripe guy. Cost $175 and came right to the house. All 4 wheels taken off and painted free hand.
Old Aug 27, 2017 | 06:53 PM
FIRE CAT's Avatar
FIRE CAT
Red Paint Stripe on Grand Sport Wheel
Old Aug 27, 2017 | 07:27 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Beugler makes a Pinstriping tool with interchangeable wheels of different widths and a built in guide for painting wheels.
Old Aug 27, 2017 | 07:49 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
I also use Tapeworks, and bought their install tool. Worked great. Had it on since November, and still looks like brand new.
To Red inserts on rims
