Driving Mode/Exhaust
Old Aug 8, 2017 | 10:25 AM
Apocolips's Avatar
Apocolips
Default Driving Mode/Exhaust
2017 Grand Sport, is there any way to set the exhaust to be full open in all driving modes without having to pull a circuit breaker?
Old Aug 8, 2017 | 10:28 AM
Foosh's Avatar
Foosh
No, all C7s w/ the NPP system have valves closing at various times even in track mode to comply with federal noise regulations, per an "Ask Tadge" answer posted here.
The only way to keep them open all the time is to pull the fuse, or install a Mild-to-Wild module, which simply controls power to the fuse with the press of a button.
Old Aug 8, 2017 | 10:37 AM
vbdenny's Avatar
vbdenny
The open NPP exhaust is not obnoxiously loud anyway. Simple to pull 42 fuse and store it in a spare slot. Still quiet compared to aftermarket but noticeably louder than normal. No biggie just a little extra for those who like it loud. I guess Corvette could pipe in the sound like some other manufacturers but that is just weird.
Old Aug 8, 2017 | 10:50 AM
Panhead51's Avatar
Panhead51
Mild/Wild was best option for me so I don't **** off the neighbors every morning.
Old Aug 8, 2017 | 12:15 PM
dvilin's Avatar
dvilin
Old Aug 8, 2017 | 12:25 PM
Foosh's Avatar
Foosh
Agree, that's what I did. Although I keep my M2W on the open setting (fused pulled) most of the time, there is a noticeable drone in 6-7 (7MT) at legal highway speeds with the fuse pulled. The M2W is a convenient way of eliminating that drone without pulling over and reinstalling the fuse.
Old Aug 8, 2017 | 01:25 PM
xp800's Avatar
xp800
If you're interested in the DIY approach to the M2W:
https://www.corvetteforum.com/forums...ob-how-to.html
On page 4 there's a post on where to find a ground in the fuse box, so the ground wire doesn't have to stick out...everything fits inside the fuse box.
I've made this contraption for my car, and it's GREAT! I've actually been meaning to go back and move my ground inside, so this thread has reminded me.
https://www.corvetteforum.com/forums...post1592266542
Old Aug 8, 2017 | 04:27 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Mild 2 Wild is very handy. Mines programmed to use 2 of the Homelink buttons for on and off.
Old Aug 8, 2017 | 08:08 PM
Kevin A Jones's Avatar
Kevin A Jones
Seems much simpler to just pull the fuse!
Old Aug 8, 2017 | 09:11 PM
vbdenny's Avatar
vbdenny
It is
Old Aug 8, 2017 | 11:17 PM
xp800's Avatar
xp800
It is
Sure it's "easier" (and free), but you lose all control of the valves without putting the fuse back in.
I leave the Engine Sound Management in Stealth, so when I need to talk on the phone (or leaving at 5am) I push my remote button and all is instantly quiet. All other times, V8 glory (I have V4 disabled).
The DIY remote method is $25 in parts. WELL worth it. And this is from the OP of the NPP fuse pull thread in Tech...
Old Aug 9, 2017 | 02:36 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Realize that if you have an automatic, the exhaust is going to get quiet whenever the engine's in 4 cyl mode, whether you pull the fuse, use a Mild to Wild, or whatever.
Old Aug 9, 2017 | 02:44 PM
i3kc's Avatar
i3kc
Under your customisation menu / sound management, turn off the automatic sound enhancement and it will be set to full open on all driving modes.
Old Aug 9, 2017 | 02:49 PM
woodsguy's Avatar
woodsguy
If this is the case why is it just now being revealed, lol! I'll check it out.
Old Aug 9, 2017 | 04:05 PM
Apocolips's Avatar
Apocolips
Thanks, but isn't that from an earlier year car than the 2017?
Old Aug 9, 2017 | 04:21 PM
woodsguy's Avatar
woodsguy
Didn't come up exactly like this, next time in car will try again.
Old Aug 9, 2017 | 04:35 PM
i3kc's Avatar
i3kc
Oh yeah, my bad. I forgot that that newer ones allow require/allow you to select Stealth, Tour, Sport or Track tones if not on Automatic (No off option). When I first posted, I took a internet picture and it's been a while since I went into the settings menu. Attached is a picture of the exhaust tone options on my 2017.
To Driving Mode/Exhaust
Old Aug 9, 2017 | 04:43 PM
Boiler_81's Avatar
Boiler_81
No C7 has full open all the time. As stated above the only way to have them fully open is to create an open circuit for the valve control. This can be done by removing the fuse or by the use of a mild to wild system.
The system is programed to close under certain conditions in order to pass federal drive by noise standards.
Old Aug 9, 2017 | 04:46 PM
breakskeet's Avatar
breakskeet
Correct
Even when you set the mode like this it will not keep the valves open all the time.
As an additional note, on my 2017 Z06, when I pulled fuse #42 and the car went into V4 mode it sounded horrendous! If you are going to pull the fuse to have it open, especially if it is and A8 that will go into V4 mode regardless of driving setting, I would get the AFM V4 disabler. Only way to disable AFM in an A8 is to manual shift with the paddles. Lucky for me Callaway disables the AFM when they install the tune for their SC757 package. I also installed the Corsa x-pipe and sport exhaust so no more valves for me anyway.
Old Aug 9, 2017 | 05:18 PM
nuke_1's Avatar
nuke_1
So I am confused by all this. When I set the exhaust to track the valves are open, if I rev the car they stay open, at what point do they close and then reopen when set to track mode? I have a 2018 M7 GS. Thanks!
