A/C drain
Old Aug 9, 2017 | 04:25 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Default A/C drain
Does anyone know where the AC drain hose is because ever since I've had my car, (2,000 miles) there's never been any water running out from under it after I use the air conditioner which is everyday in 100 degree heat.
A pic sure would help!
Old Aug 9, 2017 | 04:35 PM
vbdenny's Avatar
vbdenny
I've noticed the same thing. I think I heard they designed it to drip on something hot under the car. Seems to evaporate before hitting the ground. Weird as car AC usually put out a lot of water.
Old Aug 9, 2017 | 04:42 PM
TEXHAWK0's Avatar
TEXHAWK0
Looks like it is next to the starter on the firewall..
Normally it drips on the exhaust, so you would still hear it sizzle even if it never made it to the floor.
The amount of water depends not so much on the outside temperature, but how much humidity is in the air..
Old Aug 9, 2017 | 08:52 PM
2cnd Chance's Avatar
2cnd Chance
Default Thanks!
That explains that sound when I park the car in the garage.
Old Aug 9, 2017 | 09:36 PM
Kevin A Jones's Avatar
Kevin A Jones
I hear the sizzling sound but still get quite a bit of water draining under the car.
Old Aug 9, 2017 | 10:32 PM
vbdenny's Avatar
vbdenny
Yup. With the high humidity in the summer, drips a lot more. Been very humid in the Beach. Only time I see it on the floor is in high humidity.
Old Aug 10, 2017 | 08:24 AM
Apocolips's Avatar
Apocolips
When I had my 2014 Stingray I would hear the “sizzling” sound whenever I pulled it into the garage and never noticed any stains on the floor. Now with my 2017 GS I never hear the sizzling and have noticed a white stain that goes from under the car to the drain in the garage. By the way, this stain is very difficult to remove. Could they have forgotten to install a drain tube that drains on the exhaust?
Old Aug 10, 2017 | 10:46 AM
TEXHAWK0's Avatar
TEXHAWK0
Pretty easy to use a mirror to check.
Old Aug 10, 2017 | 11:04 AM
VNAMVET's Avatar
VNAMVET
Tons of humidity here in central Fl. Thank you for the schematic!
I don't get any water or Sizzle or anything from under my car after driving 50 miles with the air conditioner on.
Kind of worried about the condenser (?) filling up with water and overflowing under the floor which is happened before and another Corvette I had a 2008 ZO6.
Old Aug 10, 2017 | 11:29 AM
TEXHAWK0's Avatar
TEXHAWK0
I think on my C5 they had a design with a flapper so that incoming air at speed would not blow the water back into the condenser and they did stop up. Now they have a tube but might clog up easier, or if tube is missing it could be air pressure around the engine could be keeping it from draining. No water at all, is not good.
Old Aug 17, 2017 | 07:34 PM
Highplains's Avatar
Highplains
Has anyone come-up with an solution or answer as to why some cars have absolutely no condensation under the car or dripping on the exhaust? I ask because my car is one of them. The drain on my 2016 C7 is in the very corner of the engine compartment back against the right front bumper where it meets the door. An odd looking tube just over an inch in diameter with a flap on the end. I've even poked something up there to see if there was any moisture and found nothing. Never have had any water on the floor of the car. This is the second summer this way.
Old Aug 17, 2017 | 09:35 PM
TEXHAWK0's Avatar
TEXHAWK0
That sounds like the drain from the area in front of the windshield, not the AC.
Old Aug 17, 2017 | 10:43 PM
Highplains's Avatar
Highplains
Thank you very much for that. That was information from a Chevy dealership mechanic. Guess I need to back-up and take another look so I can make sure it's not clogged.
Old Aug 18, 2017 | 10:42 AM
TEXHAWK0's Avatar
TEXHAWK0
This link is for a C5, but the cowl drain udders look like the photos in this link..
Note how the ends are closed so air does not keep water from draining.
https://www.corvetteforum.com/forums...ain-udder.html
Old Aug 18, 2017 | 10:52 AM
Highplains's Avatar
Highplains
Those look like the ones that I was originally told were the drains although without getting under the car, I can see only one on the passenger side tucked up in the corner where the fender meets the door.
Its difficult for me to have a dealer do any work on my car but age and the fact that I'm still on warranty have changed my mind on this one. It goes into the dealer next week for the mechanic to poke around on. If any hoses disconnect, it will be his job to fix it.
To A/C drain
