Tail light
Old Aug 19, 2017 | 08:56 AM
michel lussier's Avatar
michel lussier
Default Tail light
i just ordered a 2018 silver and im asking where i can find this tail light or if you have any suggestion about the color for the silver
thanks
Old Aug 19, 2017 | 09:51 AM
Rsaodom's Avatar
Rsaodom
Are you referring to a decal for the third brake light? I'm not sure what tail light you are referring to. Here is a pic of one I got for mine.
Old Aug 19, 2017 | 10:11 AM
dvilin's Avatar
dvilin
Old Aug 19, 2017 | 01:40 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Can you rephrase the question?
Old Aug 19, 2017 | 02:04 PM
mschuyler's Avatar
mschuyler
Originally Posted by michel lussier
i just ordered a 2018 silver and im asking where i can find this tail light or if you have any suggestion about the color for the silver thanks
I know it's hard to believe, but modern Corvettes actually come with tail lights pre-installed.
Old Aug 19, 2017 | 02:46 PM
speedlink's Avatar
speedlink
thanks
What??
Old Aug 19, 2017 | 03:04 PM
cam30era's Avatar
cam30era
"Roll me over, in the clover..... "
Old Aug 19, 2017 | 05:20 PM
michel lussier
thanks
i would like to change it which color do you suggest me and i can buy it
thanks
Old Aug 19, 2017 | 05:38 PM
Red Mist Rulz's Avatar
Red Mist Rulz
The only option for changing the tail lights is to buy the clear ones for the Z06. There are several forum vendors that can get them for you, but they're not cheap (~ $600 IIRC), and the entire rear fascia needs to come off to replace them. If you're not going to do that yourself, figure at least a couple of hundred more for labor.
Old Aug 19, 2017 | 05:39 PM
Rsaodom's Avatar
Rsaodom
I was trying to be helpful. I appreciate your attempt of humor at my post.
Old Aug 19, 2017 | 06:01 PM
davepl's Avatar
davepl
thanks
Dans la plupart des endroits, y compris le Québec, les feux arrière doivent être rouges.
Old Aug 19, 2017 | 06:18 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Old Aug 19, 2017 | 06:26 PM
jpenriquez0584's Avatar
jpenriquez0584
thanks
I did a "black cherry"....not quite smoked black, and enough so the red still shows through.
Old Aug 19, 2017 | 06:32 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
May be the dealer didn't check the right box.
Old Aug 19, 2017 | 10:05 PM
FIRE CAT's Avatar
FIRE CAT
On today's All Girls Garage they installed a Supercharger on a 2017 GS. On
the lead-in they showed the rear of the GS and the third brake light was
Corvette in LED lights. Where did it come from?
Old Aug 19, 2017 | 10:08 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Canada
Old Aug 20, 2017 | 12:46 PM
cam30era's Avatar
cam30era
I know that, and you were helpful. But I just couldn't resist. The Devil made me do it.... ;-)
To Tail light
