Just noticed today I have a "Y" shaped crack on the inside of my windshield right where the convertible top latches on the drivers side in the black area of the windshield. I've seen a number of posts where coupes have had stress cracks near the top latches on the inside of the windshield but I have not seen any convertibles having this problem. Any convertible owners out there seen this problem? I have an appointment on Thursday to see if it will be a warranty repair. I think it will be since it's on the inside in the black inaccessible area of the windshield but we'll see Thurs. Photos attached.
I do not have this problem. However I have read of a few convertible owners who have experienced damage due to the severity of the top banging shut when raising the top.
Mine does close with a "bang" but to date no problems.
With no obvious damage on the outside of the windshield the dealer certainly can not claim it is external damage as from a stone etc.
If your car is still under the 3 yr/36000 warranty I am sure the dealer will cover it.
Most often the dealer will sub it out to a company like safelite etc.
* make sure who ever does it they have done C7 Vettes before
* take note of the GM specs printed on your original windshield and be sure ONLY the correct GM OEM windshield is used for replacement. This is especially important if you have a HUD.
Took my car to the dealer today, Service Advisor and overall Service Manager inspected and agreed no outside damage. Area Service Rep. will be in later today and either authorize repair or send to GM for approval. They said I would be notified as soon as determination was made within next day or two. I'll post again when I find out.
I got my car used but I have the same crack on the passenger side. Come to find out the windshield had been previously replaced (poorly) and there a bubbles across the entire top from it expanding. Can't file a warranty claim on a part that isn't GM. Eventually I'll fix the windshield but the crack isn't growing and it isn't that much of an eye sore to me.
Dealer replaced my windshield about a month ago under warranty, used a glass company. Did a great job, you can not tell it's been replaced and only took about two hours from the time I got there until it was ready.
Some of the (early?) C7s had a piece of welding slag or something that was putting pressure on the windshield and causing it to crack. A replacement windshield would just get cracked in a while also.
If getting one replaced, I'd discuss that with the dealer and glass fitter so they can check and correct if needed.
Mine does the hard closing but no damage that I have seen to wind screen or top latching system.
(resurrect warning) I don't have the convertible, but my (noticed at pre-sales) new C7 had a crack in a similar spot. I had an IOU from my dealership. My car is currently at a detail shop (Ceramic Pro, clear bra, all windows ceramic tint, lowering bolts) and the windshield guy replaces the windshield as directed by the dealership. My detail guy noticed it was aftermarket and gave me a call. A visit to the dealership worked out the confusion (ordering guy had been recently let go) and is making it right with an OEM windshield. Keep the aftermarket on for another couple of weeks until OEM comes in.
Normally, I wouldn't balk at an aftermarket... but then again, i have never had a car as badass as this C7, so, I'm being pretty picky. I haven't seen through it yet, but my detail guy says it looks OK. Dealership threw in an oil change. They're making mine right. So...was I wrong? Insisting on an OEM? I wasn't being a jerk, but I was insistent on the OEM for the Corvette.
Dealer replaced my windshield under warranty due to delamination. They ordered a new one from GM, and called me when it was delivered.
BTW, I was told the car had to be under the original warranty for the replacement windshield to be covered, AND ALSO if the new windshield exhibited the same problem.
Since you have a new car with the windshield being replaced under warranty, demanding a GM windshield seems very reasonable to me.
OTOH-
If the aftermarket w/s seems acceptable to you right now, you might see if the dealer will put it in writing that they'll install the GM glass some time in the future, like just before the one year point; as compensation for your trouble. Corvette windshields get pitted very quickly, probably because the car is so low, and letting this one take the hits for a year before replacing is something I'd happily accept. Of course, if you only drive 2k miles per year then it's a moot point.
Just remember that "a verbal promise isn't worth the paper it's (not) written on."
Had same problem with mine. All good now. Dealer replaced the TC while they had it
I did a search for "windshield damage" and found your thread. Thank you very much for posting this. I have the identical crack in the windshield of my 2015 Z06 convertible. I noticed it several days ago and thought it was caused by a rock. I called my insurance company. They sent out someone from Safelight. He said that the windshield could not be repaired because the damage is between the glass layers. He said the windshield would have to be replaced at a cost of $840. I told him that I would live with it for a while since you couldn't see it from the inside. I figured that if it got worse, I would have it replaced.
Later that day I found your thread on CF. My warranty expires on 3/3 (Today), so I made an immediate appointment with my dealer. I brought pictures that you posted since i thought warranty replacement would be a tough sell. The service manager took one look at the damage, and said they would replace the windshield under warranty. He said that he had seen the problem several times before. Thanks to your posting I saved a lot of money. Thank you very much.
Do you have any idea what caused the crack? My convertible top slams down hard when it closes. I wonder if this could cause the crack. Maybe I should try to catch it in the future.
Had an almost identical 'half-moon' shaped crack in exactly the same place on my '15 convertible. Dealer contacted GM, GM sent glass glass mfg rep out to examine crack. It was replaced under warranty. Rep told me that they were having the SAME PROBLEM with C7's manufactured around 1/15. I also insisted that my windshield be replaced with oem as the HUD windshields are not the same as non-HUD.
This is a known issue. Mine has been replaced under warranty. Had to do with the locator tabs that locate the windshield when it is installed on the assembly line or welding slag. Recommendation from GM was to cut off the tabs when installing by hand. It has nothing to do with temps, speed or loads of any kind.
A GM field person came to the dealership to inspect mine. He inspected the tabs first thing. Had the installer cut the tabs before replacing the windshield. He said it was most often a tabs issue, but he saw welding slag as the issue on one car he examined.
Wow, what timing. My daughter had her windshield replaced yesterday in her '18 Kia. He has been replacing windshields for 10 years with Safelight. He is sent out on jobs when they do a new model for the first time which was the case for this installation. He noticed my Corvette in the garage. He said C6 & C7's are not to hard to install but C5's were. He mentioned some OEM glass, no matter what auto maker, is harder to install/align than non OEM glass specifically because of the alignment tabs. When installed at the factory, machines press fit the glass in with enough force to sometimes override the alignment tabs. The windshield installs but there is considerable force on the glass which can result in stress cracks later on. Non OEM glass does not always have the alignment tabs which makes for an easier installation. Optic issues for both supplied windshields are about the same which is low. So in some cases I guess OEM is not always better. Something to think about.
Do you have any idea what caused the crack? My convertible top slams down hard when it closes. I wonder if this could cause the crack. Maybe I should try to catch it in the future. [/QUOTE]
Norm, When they replaced mine they did not find any cause in the glass channel or alignment tab problems. But they did note that my convertible top did seem to slam down with some force, they did some kind of adjustment to it and now it does not come down so hard but I still use my arm to break it's fall. Gvnski
