Auto locking
Old Aug 25, 2017 | 12:00 PM
buckeyebob's Avatar
buckeyebob
1st Gear
Default Auto locking
Can I lock my 2017 grand sport automatically after I exit my car without using key fob
Old Aug 25, 2017 | 12:04 PM
JakeC7GS's Avatar
JakeC7GS
St. Jude Donor '17
Yep. Look in the Settings menu. You can even turn on/off horn notification.
Old Aug 25, 2017 | 02:01 PM
TEXHAWK0's Avatar
TEXHAWK0
Funny, you can turn off the auto locking, but you cannot completely turn off the auto unlocking.
You can set it where the passenger side does not unlock when you approach the car, but the driver door will always unlock.
Made me wonder if the car was really locking, and I had to put the fob far enough away to test if the door was staying locked.
Old Aug 25, 2017 | 02:22 PM
defaria's Avatar
defaria
And thus you determined how to turn off auto unlocking - leave your FOB somewhere else!
Old Aug 25, 2017 | 02:54 PM
madrob2020's Avatar
madrob2020
'16 Z & I've loved having to just walk away w/o fumbling for the fob-maybe even hitting unlock or panic by accident. I have it set so horn beeps to assure me it locks. Once I walked away-whoops no beep- went back, door wasn't fully closed (damn airtight cars).
Old Aug 25, 2017 | 03:02 PM
dbirdhouse1's Avatar
dbirdhouse1
Default I've been spoiled
Both my wife's Prius and, of course, my '14 have doors you don't need to press any buttons to unlock.....I have my son's 2010 Subaru Sti for a few months (fun to drive) and I HAVE TO PULL OUT THE FOB AND PRESS THE BUTTON TO GET IN, how archaic! (I won't even dwell on a few of my first cars where I could only get in by opening the door from the inside)
Yup, I've got it good
Old Aug 25, 2017 | 03:28 PM
Kent1999's Avatar
Kent1999
That's how I feel whenever I get into a rental car... "I have to use a KEY to start it? How quaint!"
Old Aug 25, 2017 | 03:29 PM
HAD2HAV2's Avatar
HAD2HAV2
At first I liked the auto-lock feature until one day I went out quickly to retrieve something out of my 2015 and couldn't get in. I have 2 garages, one double and one single, that are attached to each other with the largest garage attached to the house. Of course the Vette is parked in the single,furthest garage. So I have switched back to the FOB system to my dislike.
Old Aug 25, 2017 | 04:18 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I have mine set to autolock with horn beep but it has never auto unlocked. I have to either push the Fob button or grasp the door handle and push in the rubber thingee.
Old Aug 25, 2017 | 05:01 PM
Kent1999's Avatar
Kent1999
That's exactly how it works.
Auto unlock only enables the door pad aka, rubber thingee.
If it was still locked, you wouldn't be able to open the door.
Were you expecting a honk when it auto-unlocks or something?
owc6's Avatar
owc6
That is what people are somewhat erroneously calling "auto unlock." It is not a true auto unlock where the car unlocks as you approach it.
Old Aug 25, 2017 | 05:17 PM
Kent1999's Avatar
Kent1999
Technically correct. The autounlock command is only completed when you press the door pad. But to the user, it is functionally identical. Walk up\press latch button\door opens -- no fob press needed.
The old gen Vette's autounlock was annoying ... physically unlocking and then re-locking the doors every time you walked by.
C6/C7 got it right.
Old Aug 25, 2017 | 05:22 PM
owc6's Avatar
owc6
Yes. I do believe we are saying the same thing, and thank goodness it's not on our cars, because that ate some fob batteries big time!
Old Aug 25, 2017 | 07:47 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I still think it does indeed unlock the door before you touch the pad. But what do I know.
Old Aug 25, 2017 | 07:52 PM
Kent1999's Avatar
Kent1999
Since the C7 does not 'scan' for a fob 24/7, there is no way it can 'know' you are approaching. When you press the door pad, it THEN scans for a known fob -- not before.
Old Aug 25, 2017 | 07:59 PM
owc6's Avatar
owc6
It absolutely doesn't do that.
The car doesn't constantly quest for the fob. When approaching the car, it does not do a thing until a pad on the door or a button on the fob is pressed. If the door pad (or trunk/hatch) button is pressed, the car's antenna on one of those three places (whichever is pressed) will send a very low powered query for the fob, and then the fob answers, and the door is unlocked.
If you press a button on the fob, the range is much greater, and the car, if it's in range, will unlock the door(s) or the hatch.
Old Aug 25, 2017 | 08:05 PM
rmorin1249's Avatar
rmorin1249
Unlocking the door is not the same as actually opening it. At least this is my definition. You can unlock the door with the fob but you have to open it by pushing on the rubber pad. It will open whether you have unlocked it with the fob or if it still locked. Peace.
To Auto locking
Old Aug 25, 2017 | 08:22 PM
Kent1999's Avatar
Kent1999
True, but on the C7 there is no mechanical "locked" state, only a value in the computer as to whether the car needs to look for a fob when the pad is pressed. The door will *never* open with the pad without first checking that value. So, truly, by design, the door is *always* locked.
If you press the "unlock" on the fob, it just sets that value to "no fob needed" (simplified, but you get the idea).
Old Aug 25, 2017 | 10:48 PM
madrob2020's Avatar
madrob2020
Old Aug 25, 2017 | 10:54 PM
owc6's Avatar
owc6
Originally Posted by madrob2020
Obviously, the actualities and the practicalities bore you. Time to go to bed.
