Maintenance After Track Use
Overall car was fantastic! However on the last run towards the end I could feel the brake pedal getting soft so I hit the pits and called it a day. I'm guessing upgraded brake pads for the track and a higher temperature resistant brake fluid would be beneficial?
Regarding brakes I hope you put in high temp brake fluid. If not do that, if so then it's time for a track pad change.
One other maintenance to not forget is the rear diff but I think it's like 24hrs of track use but I plan to just make it an annual maintenance item.
Flush the brake lines with fresh (500º+) fluid.
If oil has more than 1,000 miles on it change the oil.
Check and top up the differential oil.
Check and top up the transmission oil or ATF.
Check the brake pads for wear and rotors for width.
Check tire pressures and tread depth.
Check coolant level.
After a track day:
Change the oil.
Check tires for pressure and tread depth.
Schedule a transmission oil change,
Schedule a Differential oil change,
check brake pads for wear and rotors for width.
I had an HPDE on AAA track in Fontana, but didn't change to 15W-50 before hand. Threw a rod, destroyed the block, and the oil hit the catalytic converter and flashed. GM said, "Too bad. You didn't follow owner's manual instructions. Your fault. No warranty. Not our problem." For me it's been an expensive ordeal. Bottom line: Read every word of the manual, and do what it says, or GM will leave you high and dry, without a kiss.
2015 Procharged z51:
I have ran numerous track days (three 20 min sessions) with 5W-30 hitting near max coolant and oil temps on 100 degree ambient days (and I drive the **** out of it) with no problems.
All I have done for track prep for the past 2 years was high temp brake fluid. And after every 2 track days or so, i'll bleed the brakes.
I am getting a bit more serious and now finally changed to 15w-50 on my next track day and since I live in Texas and only drive it during warm days, i'll never go back to 5w-30 and will change at the intervals the car asks for (if below 30% or so, I'll change before the track day). I also have track pads that will go in this time around.
In my opinion, unless you're an high intermediate to advanced level driver, then all you need is high temp brake fuild. If your track has long straights (120+ mph), then you'll also want track pads but its not necessary, you just have to be smart. A soft pedal is brake fluid, a normal pedal and no bite is pads, try to get used to knowing the difference if you don't know it yet. You don't need to change the oil before/after each day, that's overkill unless you're trying to keep GM repairing it. Like Pete said, change to 15w-50 and keep it in if you plan on doing multiple track days, if not, whatever.
Otherwise.... do all your visual fluid and wear checks including rotors. Check your tires for wear/damage, if you plan on doing more track days, you probably want some camber. Put your tires back up to proper pressure (hoping you lowered them before going on track).
You should always have new fresh brake fluid from an unopened bottle before your track day. If you haven't already, learn how to bleed (flush) the brakes yourself, and save a whole bunch of money. Plus, dealerships don't always do it the way you would. I had them do it once on my C4, and they left the wheels on, getting fluid all over the wheels. I bitched at the tech about it, and then made them do it again because they put in the wrong stuff. I noticed that he took off the wheels the second time.
Oil changes should be more frequent, but the advice given above is probably spot-on. I wouldn't bother with the 15W-50 unless you were in a hot climate, but hey, it's cheap insurance so why not?
Racing brake pads are probably only needed for advanced drivers or on really high speed tracks like Road America. Back when I would swap pads between street and race, I'd also have a dedicated set of rotors for the different pad materials.
As far as what is required now, I believe the owners manual specifies to change the diff fluid after your first track day. Changing the oil or trans fluid after every track day seems excessive unless you just plan on doing one a year.
But get the 50W oil in next time. I have heard the GM warranty denial a couple of times because the car was on the track with stock oil.
"Not changing the engine oil to
15W-50 may cause engine
damage. Engine oil must be
changed to 15W-50 synthetic."
I plan on upgrading the brake fluid to a high temp fluid which I believe is OK to leave in the car. Meaning it's not going to cause any issues using high temp brake fluid for daily driving.
Is the 15W-50 better do to the higher RPM's and constantly being on the throttle? The track I did was the ROVAL at Charlotte Motor Speedway, so you have an inner road course section which doesn't have any straights really or time to cool the brakes. Once you get on the oval you are flying along around 140mph. Coming through the tri-oval around 120 and having to slow down to about 40 to make the hard left hander.
My 3 runs were about 15 minutes each. Car is a Z51 with 22K miles (2014) with 7 speed.
After a track day:
Change the oil.
You can easily go several events without changing the oil.
There is no need to change transmission fluid that often on an M7. I did 16 track days last year and have 10 so far this year and haven't touched the trans fluid in my M7. It still shifts fine after a couple thousand track miles.
Other than the first diff fluid change which is required after the first track event it is only required to change diff fluid after each 24 hours of track usage.
Considering you get about an hour and half or less of track time during a typical track day you can plan on doing 16 track days between diff fluid changes.
Bill
Just ordered some street/daily driving brake pads. I noticed I have had a squeak ever since I got back from the track. Not sure if I abused the stock Z51 pads or not.
