School Me On A8 Problems...
If it doesn't break by the end of the warrantee, I figure it will likely last me a long time. But if it fails at 55k, it would be reasonable to put it in the "consumable" category along with the tires, brakes and fuel/oil. Frankly it seems like a great deal to have a car like that, track it, and still have a warrantee at all.
- Shuddering and tach oscillation in V4 mode while at cruise under light acceleration. This is the classic set of symptoms for a faulty TC, and for the past couple of years the fix was to replace the TC and do a fluid flush. The fix was not always successful in the first two TC revisions and some owners had to endure two and occasionally three TC replacements. GM has produced at least three revisions of TCs, a new one introduced when the previous revision was not successful. The latest TC # to my knowledge is 24280631 and fluid is 19353429 (Mobil 1 HD low-viscosity). As of last spring the fix has been the flush only.
Mine was finally fixed in Feb. 2017 by replacing the TC and fluid, and for the two weeks I owned the car thereafter it worked fine with no more symptoms. By that time I had had enough and bought a new GS M7, as at that time there was no assurance the fix would be permanent, and I would doubt it is even today.
- Delayed engagement when cold. This may only relate to 2015 models and is covered in TSB #16-NA-14. Mine would do it about once every three months, never in the presence of service personnel, so they refused to effect this fix while the tranny was out of the car for the TC replacement (believe it or not).
As for the percentage of cars affected, it may be higher than we think because some may have the shuddering problem and don't know it, thinking it is just road imperfections. My shuddering was rather innocuous and sporadic at first, getting worse after about a year. By 18 months it was doing it every time I drove the car and was able to demonstrate it to the dealer. I didn't notice the tach oscillation until I read about it here, so some may not have noticed that either.
FWIW, these are the part numbers as of March 2017, presumably in chronological order. My original was 24273061 and the replacement was 24280631. Not sure what cars got the first TC #, as mine was a Dec. 2014 build, but that was six months into the MY. Maybe they saw problems and started the revision sequence just before that. We'll never know, I'm sure.
TC #s: 24264542, 24273061, 24279495, 24280631
