Fob
Old Sep 6, 2017 | 03:30 PM
Deftly's Avatar
Deftly
Default Fob
Any way to know which FOB is which, 1 or 2? Both of mine are stamped #1 as best as I can make out.
Old Sep 6, 2017 | 03:38 PM
Kraz8s's Avatar
Kraz8s
Honestly you are going to have to set the seats with each fob and sort it out that way.
Old Sep 6, 2017 | 04:12 PM
DanZR1's Avatar
DanZR1
It is strange to me that they are not marked. My CTS-V and the wife's C6 are both stamped 1 & 2. IIRC, just grab one fob get in the car and start it. I *believe* at some point in the start up sequence, the DIC says, "Key 1 detected" or something like that...
Edit: It says, "You are Driver #1 (or Driver #2 using her key) for Memory Features". Comes up on the DIC as soon as you enter the car with the fob. My wife's fob (#2) has a girly key ring on it, mine does not...
Old Sep 6, 2017 | 04:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Unless you mark them to know which is which, until you start the car with her FOB and the seat crushes you against the steering wheel, nope.
My wife's FOB has no keys on the key ring, mine does.
Elmer
Old Sep 6, 2017 | 06:06 PM
vbdenny's Avatar
vbdenny
I keep one fob out, the other in the safe. Corvette is a one person car.
Old Sep 6, 2017 | 07:33 PM
C5_Tom's Avatar
C5_Tom
Use your alternate FOB a few times and then go back to the primary. The first time or two you use the primary the FOB number will be displayed on the dash. You will then know which number the car thinks it is and you can mark it as such.
17 GS
Old Sep 6, 2017 | 08:18 PM
eboggs_jkvl
Moderator emeritus
It won't do that on my 14! Quantify your answer to include the specific year.
Elmer
Old Sep 6, 2017 | 09:51 PM
owc6's Avatar
owc6
Elmer
It was a big source of confusion early on, as we all muddled about trying to figure a way to determine which fob was which, and then set all the memory functions.
Old Sep 6, 2017 | 10:31 PM
SilverFish's Avatar
SilverFish
There is a way. If you pull your key out from the bottom you will see a small hollowed out area with a very tiny 1 or 2 inside.
Old Sep 6, 2017 | 10:41 PM
owc6's Avatar
owc6
The numbers don't (necessarily) mean anything. Many have gotten two #1s or two #2, and think about it; it's on the key which is removable, not the fob. The fobs are numbered strictly by the order in which they were programmed.
Mine came with the numbers switched, which likely means that someone switched the keys before delivery. Probably some bored salesman.
Old Sep 7, 2017 | 02:41 AM
DanZR1's Avatar
DanZR1
I have a 1 and a 3. Fob still registers as a 1 or 2, so I suspect those numbers are not associated with the electronics in the fob...
Old Sep 7, 2017 | 05:51 AM
eboggs_jkvl
Moderator emeritus
... and you would be correct.
Elmer
Old Sep 7, 2017 | 12:43 PM
joemessman's Avatar
joemessman
I have three FOBs. Why is that? I'll tell ya.....A couple of days after owning the car my wife comes to me. "I can't find the thingy!" Well we looked and looked and looked. Gone. So I went down to the dealer and bought another. With the key, the FOB and reprogramming it cost $245. The week after she goes to her art school and the teacher there say's. "Did you loose this?" My wife says yes. The teacher said she found it in the drive way and held it there for her to give it to her at the next art class. THANKS A LOT!
I now keep the found one in the safe. You can't have too many FOBs is now my motto.
Old Sep 7, 2017 | 12:54 PM
SilverFish's Avatar
SilverFish
That's too funny And sad. You'd think the teacher would have called her.
Old Sep 7, 2017 | 01:26 PM
Deftly's Avatar
Deftly
I can't figure it out. Are the seats supposed to move to the FOB memorized position when you open the car door or do you have to push the desired button on the door? In other cars I have owned the seats move to the FOB memorized position when the door is opened. My 2016 Vette not so. What is the point of FOB 1 and FOB 2 then? I have watched every You Tube video on the subject. Very strange system.
Old Sep 7, 2017 | 03:56 PM
eboggs_jkvl
Moderator emeritus
A6/8 or M7. Its different for both.
Elmer
Old Sep 7, 2017 | 04:42 PM
Deftly's Avatar
Deftly
Sorry, A8
To Fob
Old Sep 7, 2017 | 05:06 PM
eboggs_jkvl
Moderator emeritus
Sorry, A8
Ok, choice.
1) hold 1 or 2 in and everything moves,
2) start car and everything moves.
Wife can't reach brake pedal as I have the seat go full back to exit. So, she holds in button #2 and the seat moves to her settings and then she starts the car.
Elmer
Old Sep 7, 2017 | 05:16 PM
Deftly's Avatar
Deftly
Ok, choice.
Elmer
OK, so nothing is supposed to happen when the car door is opened? Guess my car is doing what it was engineered to do. Thanks.
Old Sep 7, 2017 | 05:18 PM
eboggs_jkvl
Moderator emeritus
Yup.
Elmer
