Follow the OM recommendations, at least during the warranty period. The bad thing is having to change it every year even if it hasn't been driven much.
I used to fly and work on light airplanes, and the oil was changed based on hours of engine run time, not revolutions. Fifty hours was the norm, which usually works out to five to seven thousand miles at 75% power settings. That's much different from what a car engine sees, though.
Airplane engines run the same RPM most of the time so it is possible to use hours. Unfortunately auto engine vary the RPM's constantly so it is impossible to use hours for run time
Nearly everyone here will say follow the OLM, even with its aggressive 1 year time component.
My philosophy is do what you are comfortable with. I personally don't believe in the time component until it gets over 2 years (and that's still somewhat mileage dependent).
You'll also get people saying you have to follow the OLM to keep your warranty. Which is FUD, it's recommended to follow not required. Just don't be abusive with your oil change schedule.
Just because I have quite a few cars and trucks and service them myself I stick to the 5,000 miles. Its just easier for me.
I still don't understand that logic. If your cars have oil life monitors, you don't need to remember mileage, you just change the oil when the monitor tells you to do it.
