Oil Life 13%
#61
What an engineer categorizes as fundamental and what a user categorizes as fundamental are not the same thing.
In terms of the owners manual, what you can always count on being correct is the capacities and the specifications for the fluids which should be in it.
The maintenance intervals are copies and the same in nearly all manuals (Corvette has a modification now for the 500 mile oil change, but otherwise that page is the same old same old).
And I've met plenty of engineers (specifically AT GM) who are uncaring, ineffective, and incompetent. So you'd be right about that.
As far as the OLM being perfect, of course it isn’t, and the more unusual your driving habits, the more likely it is to give questionable results. It also has some safety factor built in, so if you don’t have high risk driving habits, you could routinely exceed it without serious risk. But for the majority of people with reasonably normal driving habits, it gives a good, safe result.
As I have mentioned here on the forum a number of times, since my C6 is out of warranty and since I'm a bit of an "oil analysis nut", I have been doing 2 year oil changes with this car. On my most recent oil change I went 2 years and 10,000 miles, and the oil analysis results proved it was safe. I'm not recommending anyone on here do this while under warranty, but once you're out of warranty if you're always taking the car on longer trips whenever you do drive it, but you're only putting a couple of thousand miles a year, I think you're perfectly safe to go 2 years if you wanted. I'm pretty sure very few people here will ever do that.
As long as you are just driving infrequently, but when you drive, you get things hot, the above does not apply. The thing that stresses the pH stabilizers and anti-oxidants is liquid water in the oil via condensation of water vapor in piston blowby. Once the oil gets hot, that water is driven off. But if the oil never gets hot due to short trips, you are in potential trouble.
#62
The other big mistake folks make when, for example, putting a car away for the winter is starting it for awhile, letting it idle in the driveway. That is a terrible practice. If you're not going to drive it long enough to get the oil above 175º, you're much better off not starting it at all.
The following 2 users liked this post by Foosh:
joemessman (09-29-2017),
LT1 Z51 (09-29-2017)
#63
Corvette Enthusiast
All companies have a mix of high and low performing individuals. The question is, are there enough of the former to counteract the latter. If you think that answer is no, then maybe the manuals are crap, but more importantly, their products would also be crap. So why would you buy from that company?
No there are not enough good engineers to combat the latter. Detroit (GM, Ford, and the US arm of FCA) have difficulty attracting top talent as the Metro Detroit area is undesirable to many people from the East, South, and West parts of this country. We also don't get the foreign engineers like we used to, they mostly go into tech now.
Why would I buy a Corvette if this is true, because sadly this is true on some level across the entire industry and as stated above specifically for the US OEMs. I do however work in the industry and support my industry as a matter of personal interests. I bought a C7 specifically because I worked for the supplier who designed and manufactured the Steering System (was ZFLS now Bosch) and I was on the project. The design work of the mechanicals was done locally, but all the SW and electronics was designed (and programmed) in Germany. Now I work for Ford so I buy Fords (and they don't make a Corvette competitor either).
If I had to say who has the best environment and attracts the most talent it would be Ford. But that's because Ford does the most in house engineering versus GM and Chrysler (Chrysler does the least). The real talent, and this is true outside of powertrain specifically, is in the supply base. The big German and Japanese suppliers have on many levels the best engineers. The Japanese and German OEMs are better at leveraging these suppliers than the US OEMs are. But the US OEMs are getting better, while the Japanese and Germans are now entering into "cost down" mode like the US industry was in the 80's. The days of engineering for the sake of engineering in Automotive are gone, you are put in a box.
#65
True, the but value of threads/forums like this is more about educating the rest of the community than just answering OP questions.
#66
The key point in the above is "warranty." I would not violate the recommendations in the manual at least until it has expired.
#67
So many answers.
