Claybar on a new C7?
#61
Received 5,217 Likes
If you want truly "perfect" paint, the place to start is not with the factory paint job (unless the new facility does MUCH better than I've ever seen). LOTS of hand work along the way that the factory will never ever do!
#62
Not sure what your point is, but it's obvious that once factory-painted, there's nothing anyone can do to make it "perfect" without completely starting from scratch. That means body panel removal, strip down to bare panels, smoothing of those panels, base coat application followed by wet-sanding and polish, and then clear-coat application followed by wet-sanding and polish.
That would be insane to do on a C7, and it's only seen on megabuck, limited production cars, as well as custom, show cars, and valuable restorations. If you're going to spend the money to do that, better put it on display and rarely/never drive it.
#63
I bet if someone really wanted a perfect show car finish it would cost at least $25,000, if not more since it would involve many hours of wet sanding in between each coat of paint applied (and many coats would be needed) There was an article in Road and Track (or Car and Driver) many years ago about a guy who was regarded to do the best paint jobs in the country, and I believe he charged $100,000 and would work on one car at a time and the entire process would take around six months.
