Time to go to dealer, should be able to order one. See this is your first post. New to C7s? Not being crazy mean-but you pulled correct dipstick? Dry sump is way off to side, not where someone would expect. Started thinking, surely you wouldn't be jerking our chains.
Thanks guys I've had 33 cars but never a C7 Corvette and never had a car with a dry sump system well I've been checking engine oil since I was 15 and I'm now 70 but I never saw a dipstick like this one usually you are checking the lastinch or two I didn't know you had to check like 6 inches up on the dipstick it was kind of dark in the garage I guess I should have noticed so my fault thanks for directring me in the correct direction I appreciate it I finally got it checked and it is still over full so I guess I'm going to have to drain some back out ( for you grammar folks I guess that was considered a run-on sentence) 😎
Don't feel bad. I'll be 70 next month and made the same mistake. That's why I could help. LOL
Did you get the engine up to operating temperature and the cut it off and then check the oil 5 to 10 minutes later?
Like others have mentioned, be sure you are getting engine up to temp, parking on level ground and then turning it off for 5-10 minutes to properly check level. Dry sump is very particular with the way you check it. All this is in the owners manual. Let us know if you checked it this way and if it was still overfilled. Usually this is due to the dealer adding 10 quarts instead of doing it the right way, adding 9, getting to temp and checking level then adding anywhere from 0.3 to 0.8 quarts to top off.
