Another Drop
Old Oct 6, 2017 | 04:15 PM
LT4CMG's Avatar
LT4CMG
Default Another Drop
Not sure if I’ll regret it, but dropped all 4 corners all the way on the factory bolts, then raised the fronts 3/4 turns and the rear 1 full turn. Will monitor closely for any issues, but couldn’t stand those gaps anymore. Before and after pic. Still needs to settle.
Old Oct 6, 2017 | 04:46 PM
Avanti's Avatar
Avanti
We need before & after pix from the same angle, please.
Old Oct 6, 2017 | 04:51 PM
LT4CMG's Avatar
LT4CMG
Will do buddy, just need to have it settle first. Drizzling out, just back out the driveway then back in. Will update this weekend. Should be sunny all day Sunday. And to answer your next question, Yes, both my vette and Camaro melt in the rain or even drizzle, so must wait
But I can add that it went from 3 1/2 ish fingers to 2. Lol, I know, very scientific.
Old Oct 6, 2017 | 09:01 PM
ClydeFrog's Avatar
ClydeFrog
Then I need to check & see if my wife has any bolts.
Old Oct 6, 2017 | 09:12 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
You'll be fine...no worries.
Old Oct 6, 2017 | 09:14 PM
fugly1's Avatar
fugly1
Lowering on the stock bolts -- all the way -- is a must IMO. You'll need to be a little more careful, but no big deal.
Old Oct 6, 2017 | 10:28 PM
TNSQUIRE's Avatar
TNSQUIRE
I went all the way down and left it there. Much better profile.
madrob2020's Avatar
madrob2020
OMG!
Old Oct 6, 2017 | 10:36 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
What rims are those?
What size?
Nice ride sir. She looks amazing. My lower paint isn't in as good shape tho.
Old Oct 6, 2017 | 10:37 PM
LT4CMG's Avatar
LT4CMG
Thanks guys. Feeling a bit better based on your comments, but I do have 1” wider aftermarket wheels. That’s what worries me most about rubbing issues. We’ll see though, based on all I read, I should be fine. This one never gets tracked anyway, so no extreme situations to worry about.
Old Oct 6, 2017 | 10:44 PM
vbdenny's Avatar
vbdenny
I'd love to hear how easy (or hard) it is to lower the settings on these factory bolts. Just did a look and yeah, I could drop a little more. I have a floor jack and pucks but no lift.
Old Oct 6, 2017 | 10:47 PM
TNSQUIRE's Avatar
TNSQUIRE
I did mine using a floor jack. Just need to lift each corner enough to slide under. Then use a wrench to turn the bolts to their stops.
Old Oct 6, 2017 | 10:48 PM
TNSQUIRE's Avatar
TNSQUIRE
https://www.corvetteforum.com/forums...nd-photos.html
Old Oct 6, 2017 | 10:57 PM
LT4CMG's Avatar
LT4CMG
What size?
Thank you much sir. The wheels are Stance SF03 Rotary forged in piano black. 20x11 rear, 19x9.5 front. Stretched my OEM PSS ZPs over them.
As for ease, easiest free mod. One jack to raise the car, one jack (with a pad to avoid damage) to raise the composit leaf spring to allow you to easily loosen the bolts. Lefty loosey (to lower), righty tighty (to raise). 20 mins to do all 4 corners. Use a 10mil wrench with a ratchet loop
Old Oct 6, 2017 | 11:17 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
That's the size I'd like to get but with slightly bigger rubber. 305s I believe would be just right for the rear.
Old Oct 6, 2017 | 11:19 PM
LT4CMG's Avatar
LT4CMG
Yes, 255 or 265 front, 305 rear. But first, I must wear these out
Old Oct 6, 2017 | 11:42 PM
-HAIRBALL-'s Avatar
-HAIRBALL-
Don't forget to have the alignment checked again...
To Another Drop
Old Oct 7, 2017 | 12:01 AM
LT4CMG's Avatar
LT4CMG
Thanks Hairball, I'll let it settle, then take it in to get checked
Old Oct 7, 2017 | 02:13 PM
LT4CMG's Avatar
LT4CMG
Update. Drove about 10 miles today, the sun decided to come out. So far, 7/8” drop upfront, 3/4” drop in the rear. No issues going up my horrible driveway either.
Old Oct 7, 2017 | 11:47 PM
BuLion's Avatar
BuLion
Your center cap is not centered?
