Cargo area light
Old Oct 6, 2017 | 04:53 PM
txsnafu's Avatar
txsnafu
3rd Gear
Default Cargo area light
New to forum so please forgive if this has been covered but couldn't find any threads.
Just bought a 2016 Z51and here's my delima.... How do you get the cargo area lights to turn off when using the battery tender and leave the hatch cracked to run wire?
Old Oct 6, 2017 | 11:30 PM
LT4CMG's Avatar
LT4CMG
Yes, leave the hatch cracked open and your lights will go off by themselves.
Old Oct 7, 2017 | 12:30 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Yeah, they time out after like ten minutes.
Old Oct 7, 2017 | 12:42 AM
WMark's Avatar
WMark
St. Jude Donor '11
I've used the same trickle charger for seven years. First a '10 GS, and now my '16 C7. '10 required I close the door. C7, I close the lid. No damage to the cord.
But, if you are uncomfortable with that, the light will go off.
Old Oct 7, 2017 | 07:48 AM
txsnafu's Avatar
txsnafu
3rd Gear
Thanks all.
Patience really does pay off. Finally found answer in owners manual. It's a battery protection feature. Any electrical that stays on will time out after ten minutes....
Old Oct 7, 2017 | 08:08 AM
Kraz8s's Avatar
Kraz8s
Don't leave it open, the hatch is designed to allow you to close it while using the charger. No damage will occur to the car or the cord.
Old Oct 7, 2017 | 08:24 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by txsnafu
Thanks all.
Yep, unlike some prior Vettes you can even leave a map light on and in less than 10 minutes it shuts off! I don't bother with a charger as it's a DD and have been on vacation for 2 1/2 weeks and car starts right up. If fully charged, the battery will still start the car after ~30 days! I would not push it that far but some have.
Old Oct 7, 2017 | 08:46 AM
sTz's Avatar
sTz
I close the hatch as well. Absolutely no damage to the cord, paint, or hatch seal.
Old Oct 7, 2017 | 11:27 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Right on, I have been closing either the hatch or the trunk (depending on what Vette I own) for many years ( started 05). That is for slack periods during our good weather and for more than six months over our LOOOOOOOOOOOOOONG cold/winter season.
Old Oct 7, 2017 | 01:46 PM
Bob Beroza's Avatar
Bob Beroza
Here's a gift for anyone that has a crappy memory. I place this on my back window to remind me that the charger is connected. if you want this sign just grab the image to you desktop. Then print it out, I laminated mine to make it permanent.
Old Oct 7, 2017 | 03:22 PM
Rebel Yell's Avatar
Rebel Yell
Me too, and mines a vert.
Old Oct 7, 2017 | 08:13 PM
Avanti's Avatar
Avanti
I just run the wire in a door window which I lower.
Old Oct 7, 2017 | 10:44 PM
Wjereb's Avatar
Wjereb
I just use my finger to close the latch manually and then lower the hatch slowly so it’s slightly ajar. When I disconnect the cord I press the hatch release so the hatch can be closed.
Old Oct 7, 2017 | 10:45 PM
Wjereb's Avatar
Wjereb
Old Oct 7, 2017 | 10:52 PM
owc6's Avatar
owc6
I can't address the possible damage to the cord if the hatch/trunk is closed on the cord (no channel like the C6 door), but I can say I have left the trunk open for the last 3 1/2 years every day, and never had my car on a tender, and the open trunk light is a non issue.
The light times out.
To Cargo area light
