Mine match. TPS read out appears accurate all the time. Have now abandoned using manual gauge on Corvette. Perhaps I'm mistaken but I think I heard there is a menu to show tire temperatures by color code or could be my Video game
Yes, there is, and Zymurgy published the temps defining freezing, warm, and hot tires in another thread recently. Turns out that display is of very little use, because starting at around 40ºF, it indicates the tires are warm. That is not the definition of warm tires.
New sensors (my '18 C7 and my '16 Ram) are MUCH more accurate than the ones in my C5 ('01 and later '04-sensors) have ever been... all of the latter have always been 3#s or more off, and still are.
What is interesting is that OnStar's messages regarding tire pressure readings on the C7 have never had anything to do with any measure that I take... at any time, either via the car's sensors or any number of Meiser and digital gauges!
...the ones in my C5 ('01 and later '04-sensors) have ever been... all of the latter have always been 3#s or more off, and still are...
Your avatar shows you live at the Bonneville Salt Flats. The elevation of the Flats and Salt Lake City is around 4,200', and because the display of pressures is a little less than 1psi for each 1,000' above SL, all the Vettes in your area will display around 3psi less than your tire pressure gauge.
However, they transmit the tire pressure and temperature to the TPMS.
The TPMS display of tire pressures is affected by the elevation the car is at.
For every 1,000 feet above sea level the pressures displayed will be almost 1 psi less than your tire pressure gauge.
Owners in the mile-high city of Denver tell us their display of pressure on the DIC reads 3 or 4 psi less than their tire pressure gauge indicates.
At 7000', all of my Corvettes for the past 11 years have read a consistent 3 pounds less on the TPMS than a gauge. The Hondas do the same thing--a low pressure warning (general, not a specific tire as on the Vette) pops up at 29 psi on the gauge. The TPMS thinks it's 26--6 pounds below recommended. You get used to it here. Just have a good gauge.
And here's another post in a different thread where C7 owners are talking about the same lower display of pressure at high elevation that all the previous gens of Vette have had:
Depends on the altitude at which you drive. Sea level, very accurate. Now, at 6,000 feet they're off, they read low by about 4 pounds. As the altitude goes up, they read lower and lower than actual.
And egenity followed up:
Originally Posted by eginity
I can second this. I am in Denver (5200-5300ft) and the TPS sensors are consistently 3-4psi lower than a quality gauge read.
