No drill spoiler install?
Old Nov 12, 2017 | 08:09 AM
bsedwebt's Avatar
bsedwebt
Default No drill spoiler install?
I have purchased a Z51 OEM spoiler and want to install it without drilling holes on my base Stingray. I was thinking I could remove the spoiler screws, clean it really good, use adhesion promoter and apply RM45 3M adhesive tape. This stuff is REALLY strong - not just ordinary stuff - this is industrial stuff. I have used it in several projects without fail in outdoor situations other people have expected failure - it has yet to fail years later and is just as strong as when it was a week after install. Any ideas?
Old Nov 12, 2017 | 08:36 AM
Globeman's Avatar
Globeman
Mine is held on with 3M tape. It's well attached, not going anywhere.
Old Nov 12, 2017 | 10:28 AM
joeybsyc's Avatar
joeybsyc
Sure... many have done it with no issues.
Old Nov 12, 2017 | 10:32 AM
TEXHAWK0's Avatar
TEXHAWK0
I would still prefer metal fasteners...
Why risk it coming loose if you are never going to remove it anyway?
If the tape is as good as you say, then if you ever did have to remove it, it may be easier to remove with fasteners and do less damage in the process.
Old Nov 12, 2017 | 11:59 AM
joeybsyc's Avatar
joeybsyc
If you ever want to remove it, fishing lines will remove it and it's a lot easier to get some tape residue off than to fill holes. It's never going to go anywhere unless you want it to... But it sounds like you already know that!
Old Nov 12, 2017 | 04:31 PM
Johnp94's Avatar
Johnp94
The spoiler rest against the brake light. Should be good.
Old Dec 8, 2017 | 09:19 PM
bsedwebt's Avatar
bsedwebt
I got the factory spoiler and cut off the mounting bolts, ground them flat and cleaned/prepped the bottom side. I used adhesion promoter on the spoiler and on the painted surface of the car - stuck the spoiler on with RP45 double sided tape and put some pressure on it for a while. It is rock solid.
Old Dec 8, 2017 | 09:52 PM
joeybsyc's Avatar
joeybsyc
Excellent... And certain to upset the drillers and bolters who are certain it'll blow off the deck lid at speed.
Old Dec 8, 2017 | 11:37 PM
TEXHAWK0's Avatar
TEXHAWK0
Yep, I always say you don't have to use bolts to hold on all spoilers or splitters, just the ones you want to keep.
Old Dec 8, 2017 | 11:46 PM
Silver C7's Avatar
Silver C7
Hope you never need body work that requires paint matching...
To No drill spoiler install?
