Engine vibration?
Old Nov 26, 2017 | 02:01 PM
Varekai's Avatar
Varekai
Default Engine vibration?
Is engine vibration normal in the Lt1? A while ago I posted about a vibration in my clutch pedal after the vehicle is warmed up, now I think it's actually coming from the engine and not the transmission, only happens after the engine is completely warmed up. I had my fiance rev the engine while I had the hood popped and my hand on the engine. Definitely a good vibration in the engine, she only revved it to another 3500. Just not sure if these are supposed to be smooth or not. I don't recall my GT350 with the flat plane crank having this vibration, and I really hate going to dealer ships.
Old Nov 26, 2017 | 02:45 PM
Avanti's Avatar
Avanti
Go to a dealer and try another one or two to compare with. It's hard to be sure what you are experiencing remotely. I don't think my LT1 is the smoothest either, but I don't feel anything in the clutch-pedal which I'd equate with your description. Did you buy your C7 new or used???
Old Nov 26, 2017 | 03:14 PM
Maxie2U's Avatar
Maxie2U
Mine vibrates slightly while idling whether at start up or after it's warmed up but there is no real RPM fluctuation. I don't feel any roughness when applying power. This I take as being normal given it's a high performance engine.
Do your RPMs fluctuate?
I agree with a previous post who said bring it into the dealer.
Old Nov 26, 2017 | 03:15 PM
Varekai's Avatar
Varekai
New, 4500 miles, been happening the last 2k. It's strong enough in the clutch pedal to make my foot numb in heavy traffic
Old Nov 26, 2017 | 03:17 PM
Varekai's Avatar
Varekai
Yes, at idle the digital rpm guage can be pretty bouncy.
Old Nov 26, 2017 | 03:28 PM
Maxie2U's Avatar
Maxie2U
I would definitely bring it into the dealer to get it checked given the fact it's still under warranty.
Old Dec 1, 2017 | 02:39 PM
Varekai's Avatar
Varekai
Went to the dealer, shop foreman said he thinks that vibration is normal since it's a large pushrod engine, and since out of all the 8 other vettes on the lot none were manual he had nothing to compare it to to see if it's normal or not.
Old Dec 1, 2017 | 03:02 PM
c54u's Avatar
c54u
I would call other dealers to see if they have M7's on the lot. If they do, book appt to that dealer service deptartment and get a comparison.
Pretty sure there should be no RPM bounce at idle.
Old Dec 9, 2017 | 02:48 PM
Varekai's Avatar
Varekai
Here's a video of the bounce. Maybe it's normal and just not noticeable to most?
To Engine vibration?
