C7 won't start
Old Nov 26, 2017 | 05:56 PM
Domc7's Avatar
Domc7
1st Gear
Default C7 won't start
Charged battery, tried jumping, lights come on, car will not turn over.
Old Nov 26, 2017 | 06:01 PM
TEXHAWK0's Avatar
TEXHAWK0
Is it finding the fob?
Where did you attach jumper cables? Should only attach at the battery, not under the hood at fuse box. You might check to make sure the fuses in the box on top of the battery are good...
Check with volt meter to see if getting 12 volts to the cable to the starter.
Old Nov 26, 2017 | 06:03 PM
Maxpowers's Avatar
Maxpowers
Need more info. Do all the accessories work? What happens when you try to start it? Does it make a click noise or anything?
Old Nov 26, 2017 | 06:39 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Any messages on the DIC?
If M7, clutch on the floor?
If A6/8 Brake pedal pressed?
Any sounds?
When you jumped at the battery in the rear, any messages on the DIC?
Big *** fuse on top of the battery, if blown, will stop a jump unless you are on the cables directly.
Need a lot more information before we can give any hints or suggested solutions.
Elmer
Old Nov 26, 2017 | 11:24 PM
NASTYC7's Avatar
NASTYC7
Get out of the neighbors garage, it's not yours and you need the fob!!!
Old Nov 27, 2017 | 12:23 AM
WMark's Avatar
WMark
St. Jude Donor '11
"Trolling down the River!!" New member, one post, and the question so general, and generic.
OP, prove me wrong. Answer the questions already asked.
Old Nov 27, 2017 | 02:17 PM
Nexxussian's Avatar
Nexxussian
Old Nov 27, 2017 | 02:31 PM
Frodo's Avatar
Frodo
Well, he said the lights come one so the big *** fuse is OK. It feeds the forward fuse panel and starter. Still, many questions to be answered.
Old Nov 27, 2017 | 03:19 PM
c54u's Avatar
c54u
Check the starter relay in the fuse box under the hood - relay fuse #54 and the starter fuse #2.
Old Nov 27, 2017 | 03:50 PM
Rebel Yell's Avatar
Rebel Yell
I'm gonna start out with the easy stuff. OP, did you try putting the FOB in the steering column transmitter then hitting the start button? If that works replace your FOB batteries.
Old Nov 27, 2017 | 04:07 PM
eboggs_jkvl
Moderator emeritus
He would get a DIC message saying that it does not see the FOB. We're asking questions to see if there are any messages.
So far, he has abandoned the thread so
Elmer
Old Nov 28, 2017 | 12:54 PM
Rebel Yell's Avatar
Rebel Yell
Elmer
Sadly Elmer we get to many of those.
Old Nov 28, 2017 | 01:16 PM
davepl's Avatar
davepl
Yup, another "I need an immediate answer to a pressing problem so I joined just for that but will never even be back to read it" post.
Old Mar 19, 2020 | 08:40 PM
Alejandro De Hoyos's Avatar
Alejandro De Hoyos
1st Gear
Default Won’t start
does make a clicking noise when I press gas pedal starter won’t turn over car was running 10 minutes ago did cam swap and loaded tune and started good but turned off and now it won’t cut back on
Old Mar 20, 2020 | 02:22 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Default Rumor has it....
Three and a half years after the question was posted, we heard that after all the advice about jump starting, he electrocuted himself trying to plug it in to a 220 circuit thinking it would give it a bigger boost - RIP
Old Mar 20, 2020 | 05:55 PM
Red08's Avatar
Red08
So true!
Old Mar 20, 2020 | 06:41 PM
Vette Ski's Avatar
Vette Ski
He probably got it running and is out there toolin' around, thanks to all your replies !
Rich
To C7 won't start
Old Mar 21, 2020 | 01:55 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You'll have to go to online and search for stolen Corvettes in that area... 3 years ago lol
Old Sep 23, 2023 | 12:22 AM
MordecaiC7's Avatar
MordecaiC7
Cruising
Default anti theft hack?
Quick question. I yanked these two out and the car wouldn't start. I'm doing this to prevent theft if someone breaks in. If they had half a brain mechanically, could they swap any of the similar fuses or relays already in the box into these places and the car would start again? If so, which additional ones would I have to remove to prevent this. I'm assuming theives won't be carrying spares with them. Also any issues you think it would cause not having these in the car while it's just sitting there or are they fine in my possession while the car is in my driveway at night?
Thanks in advance,
M
Old Sep 23, 2023 | 08:02 AM
Tinkertech's Avatar
Tinkertech
No matter what you do, professional thieves will just flat bed it away in a matter of minutes. Some special equipped tow trucks can hook up and be gone in less that 30 seconds and the driver never even has to leave the cab.
