C7 Mild 2 Wild Problems
Dec 1, 2017 | 02:22 PM
I purchased a M2W last week and received it yesterday. I installed it per the directions and cannot get the remotes to work. I have tried with hood open and closed, infotainment in stealth and auto and cannot get it to work.
If I remove the fuse from the adapter and plug it back in, it works fine so fuse is not the issue, any suggestions?
2017 C7 Z06
Dec 1, 2017 | 02:25 PM
2015 C7 of the Year Finalist
Call them and ask. It sounds as though the box isn't getting power or not receiving the FOB transmission. Did you add the 2nd fuse to the power tap?
Elmer
Dec 1, 2017 | 02:29 PM
Quote:
Originally Posted by
eboggs_jkvl
Elmer
There is no second fuse....I installed the fuse I removed from slot 42 to the power tap....is a second fuse supposed to be in the kit?
Dec 1, 2017 | 02:31 PM
bapd77
Well, the power tap uses the original fuse AND a 2nd fuse for the M2W box. You need 2 fuses in the power tap.
Does the power tap look like this?
There are 2 fuses in that tap.
Wait a second. THis might be different, crap... Let me go look.. I hate getting old!
Elmer
Dec 1, 2017 | 02:36 PM
My bad! 1 fuse, the one you removed from the block and a white wire where the 2nd fuse would be.
Dec 1, 2017 | 02:41 PM
Back to not getting the radio signal from the FOB or no power to the black box.
Looks like a call to them would be appropriate. The install is very simple. Was there a black ground wire? Good ground? Did you stretch out the blue antenna wire and secure it?
Dec 1, 2017 | 02:48 PM
eboggs_jkvl
Ground wire attached to screw near airbox. Blue wire stretched out and zip tied along fender.
Dec 1, 2017 | 02:49 PM
bapd77
Phone call time! It appears that you done good on the install.
Dec 1, 2017 | 05:25 PM
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Well it’s possible you got some older fobs. Maybe the batteries are dead.
Dec 1, 2017 | 06:58 PM
2K14C7
My guess is the fob batteries too. They do not come with very good quality batteries and they do not last long.
Dec 2, 2017 | 10:13 AM
TEXHAWK0
Definitely something to check too! Quick, cheap and pretty much would eliminate everything but the rcvr box.
Elmer
Dec 2, 2017 | 10:59 AM
Yep, I'm guessing fob batteries too.
Dec 2, 2017 | 01:27 PM
What exhaust mode do you have the car set to?
Dec 3, 2017 | 08:57 AM
ClydeFrog
I have tried auto and stealth.
Lights illuminate very bright so I thought batteries were prob ok. If not, It must be actual box.
Dec 3, 2017 | 09:01 AM
Just exchange it.
I had the same problem and it turned out to be a bad remote.
