How to change battery
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
One of the good guys on here made a PDF on how to change the battery. Pretty easy.
http://netwelding.com/Battery_Issues.pdf
Elmer
Elmer
The problem is not the electronics, but you should disconnect the negative terminal first, and then the positive. Reconnect in reverse order. Physically, it is a pain to get the carpet, aux. fuse box, vent disconnected, and everything out of the way just to be able to get it out and a new one back in...
I went ahead and took the time to remove the side panel just to make sure I did not rip the carpet trying to get it folded back..
Moderator
You'll probably need to re-index your windows. It's in the Owners Manual.
I've got it down to a few easy steps
Step One - Be a bit more discerning when choosing a battery, i.e. the
Optimas don't fit
Step Two - Be careful removing the mat, cardboard/particle board cover
as it's easy to break
Step Three - Pick up the phone and call your friendly mechanic and pay
him/her to do it, I wouldn't touch it myself.....
Simple and stress free.......
Optimas don't fit
Mine came with a ACDelco Silver series battery, and I replaced it with an ACDelco Gold series battery with a 42 month free replacement.
Actually, trusting a mechanic, even at the dealer, to take care not to tear the carpet or damage anything else is more stressful for me.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Funny in my C6 had to index both windows after I changed batteries. In my 2014 C7 only the passenger side!?
Battery was disconnected for about and hour (took my time to take pics) and expected there might be some reprogramming. None needed. My ~1000 songs on the SC card played in shuffle mode when I started the car just like they always did (and do now from a flush mount thumb drive!) No other changes.
I was that "good guy" that Elmer refereed too who made the PDF he put in his post! Thanks Elmer!
Elmer
I just commented on that post as it was asking a question re electrically issues with the battery being disconnected!
Frankly with all the programming needed for the C7 I was concerned I'd have to remember what I had set! Some of settings, like getting the car to beep when I leave were not obvious. Finding the correct menu is another issue. Fortunately I only had to index the passenger window!
Are you guys that are changing batteries doing it as a preventative measure or is the OEM battery really dying this early? I know in the hotter climates that batteries don't last as long but up here in Canada I've heard of a number of guys with Corvettes over the years that have gone well over 5 years on their original battery and I just talked to someone who went 9 years and the original battery in his C6 didn't even fail on him, he just changed it because he felt it was time.
My C6 battery failed because it had a leak!
My C7 had a low voltage since it was new. After the surface charge was depleted it was ~12.4 volts. When I got the car in October 2013 I bought the equivalent to the GM battery charger to be sure. Same result after waiting 24 hours when it had showed fully charged. Never used the battery charger again even with several 2 1/2 week vacations.
In fairness, the battery was still operating fine when I replaced it before what was coming up to it's 4th winter. There was a sale on a quality AGM battery in late summer and after replacing it would NOT want to have to do it if it went dead mid winter! When it was replaced the battery voltage was where it should be, about 12.8 volts after the surface charge is depleted in 24 hours, ~12.8 volts.
If you haven't exposed the battery, suggest you do so and learn to pull the passenger plastic wheel well cover off before pulling the carpet out from underneath. You can look at my PDF (see post #2) and see it can be done with your fingers. Only need to unclip the bottom rear. (Note that is not mentioned in the Owner's Manual.) There are posts where the dealer tech ripped it getting it out! It's unbound and an AAA person providing a jump start will surly rip it!
That said, I have an Optima in my street rod that is always on a charger and it is 8 years old. Does make me concerned as it has electric doors, no door handles and the batter is inside the car! When at car shows I always leave the drivers window open so IS needed I can get a jump! Keeping a charger on the battery will extend the life. For my Vette, which is a DD, it's a PIA and I don't do it!
I definitely will be using the battery tender whenever I know I won't be driving my C7 for a few days. I do believe that keeping the battery topped up like that can extend it's life greatly.
Good idea if it's not a PIA! I don't bother even if I'm gone for a week or more. Was on vacation with my 2014 several times for 2 1/2 weeks and even with a low voltage (no doubt a weak cell) it started fine.
In the summer we have many lightening storms (and occasionally at other times.) Have lost sprinkler controls, TV's and even LED lights (when they were off) so it's a risk keeping a charger connected. With my street rod I keep a charger attached (as it mostly is driven only to Shows) but I did most of that wiring myself from scratch and can fix if needed. It has just a few microprocessors like the digital dash and alarm system and probably some of the sound system. I can replace all of those if needed.
I would/could not attempt to fix anything electrical on the Vette! Frankly ~$150 to replace the OEM battery with a quality AGM battery in 4 years is no big deal considering what else I spend on the car!
I don't find connecting the tender to be a pain, especially since I'm really only in the habit of doing it from December to April. During that time period I have generally only driven my Corvette maybe 3 or 4 times per month, but the rest of the year I drive it at least 3-4 times per week so no tender is needed. On my C6 I plug the tender into the console and run the wire out the open driver's side window, so there is no chance I'd forget to unplug it. With my upcoming C7 I will have to make a sign to put in the car to remind myself when I have hooked up the tender in the trunk!
For your situation where you have those frequent storms and power outages/surges, why not just hook up your tender on a power bar that has a surge protector on it in order to keep things safe?
Have a surge protector on my sprinkler control. Have replace the control 3 times! On one TV, have and expensive surge protector strip with guarantee! It blew an HDMI connection! Fortunately the TV had 3 channels-now 2! If the TV goes, worth the hassle of dealing with the guarantee but that was an easy fix! Even pay the power company insurance they have something on the line but only covers major appliances.
There are some downsides in living in the always sunny South but well worth it!
Moderator
My C7 battery is just under 4 years old and still going strong. We were travelling internationally from Nov 5 to Nov 29. On Nov 30 when I went out to start our cars, my C7 started right up. My wife's not even 1 year old XT5 was completely dead, not even enough to light up interior lighting. Neither has ever been on a battery tender and both are essentially daily drivers.
As far as surge protectors are concerned, I recommend putting whole house surge protectors in your service panels. I have them in both of our service panels and in 17 years, I've had to replace exactly 2 light bulbs in the entire house. Cutting down the transient voltage spikes really prolong the life of all electronics.
aside from there being no handle to lift the battery out (OEM Delco) which is a PITA because of it's tight confines and the rear cover doesn't have an indent so it may tear when you move it to reach the battery.
