Why do my side mirrors keep changing?
Old Dec 6, 2017 | 04:55 PM
DGA3's Avatar
DGA3
Default Why do my side mirrors keep changing?
Sorry if this is "C& 101," but I've only owned mine for less than a week, and I'm still trying to learn everything!
Each time I drive, I set the side mirrors exactly at the blind spots (the proper way to do it, of course!).
However, when I turn the car off, the next time I get in, the mirror positions have changed, and I have to set them again.
What am I doing wrong?
Old Dec 6, 2017 | 05:00 PM
RonC7's Avatar
RonC7
I assume you have a 2LT or 3LT trim level. You need to save the settings for driver #1 or 2 so they stay.
Look in your manual under Vehicle Personalization.
The manual is a wonderful resource.
Ron
Old Dec 6, 2017 | 05:04 PM
DGA3's Avatar
DGA3
Ron
I have been reading the manual, but (like all cars these days) it is huge!
Thanks for sending me in the right direction, though (Vehicle Personalization).
And yes, I have a 3LZ.
Old Dec 6, 2017 | 05:20 PM
Fcal's Avatar
Fcal
Car in Park or neutral, set the mirrors and seat, (on driver's door) push the #button(beep) then push set till it beeps (2X), if I remember correctly.
Old Dec 6, 2017 | 05:26 PM
Kent1999's Avatar
Kent1999
Don't forget -- memory settings 1 and 2 are linked to FOB1 and FOB2 respectively. If you set the memory settings on setting #1, and then the next time you get into the car you are using the fob2, the settings will change to the FOB2-linked settings (settings #2).
To answer the obvious follow-up question, no, there is no physical way to tell which fob is programmed as #1 or #2 -- whichever fob was programmed 1st is the one that is set as "fob #1".
Old Dec 6, 2017 | 05:28 PM
Scoobydoobydoo's Avatar
Scoobydoobydoo
Watch the following video and it'll show you how to program the seats and mirrors into.the memory function
Old Dec 6, 2017 | 06:54 PM
JNess's Avatar
JNess
For a manual, you have to set the parking brake to get the driver's settings to return to the fob.
Something else, manually setup the 'exit' mode. I noticed that during exit, your seat slides back, the steering wheel moves up and away, and.... the mirrors move.
I set the exit to only move the steering wheel, while keeping the mirrors at my settings. So, even if you forget to set the parking brake, the only thing you have to fix is your steering wheel (that is if you are tall and already have the seat all the way back).
Old Dec 7, 2017 | 02:11 AM
Grand Slam's Avatar
Grand Slam
For those who find it hard to find topics in the manual (which should be about everyone), download a PDF version of it from the sticky threads in this forum. Then you can search the manual for subjects. I do this with every manual I can.
Old Dec 7, 2017 | 03:08 AM
GSC7's Avatar
GSC7
Press the most left button release then hold the memory position button 1 or 2 whatever you would like until it beeps twice. You have to be quick in between buttons.
Old Dec 7, 2017 | 07:26 AM
DGA3's Avatar
DGA3
Now that's the problem! I did not know that.
I have set the seat memory numerous times, and it never "remembers" my settings. Very frustrating. Watched all the You Tube videos about it and read how to do it, but it never worked.
Now I know why.
Thanks.
To Why do my side mirrors keep changing?
