GS vs Base Stingray for long distance travel
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
The following 8 users liked this post by Steve_R:
Bavaria (12-11-2017),
Crossed Flags Fan (12-08-2017),
hanks10GS (12-07-2017),
Jeffer (12-07-2017),
karlm (12-10-2017),
and 3 others liked this post.
The following 2 users liked this post by SD_Dave:
silvertc6 (12-07-2017)
A friend has a 2016 base with MRSC and we took back-to-back rides in both cars to compare, both agreeing the difference was barely noticeable. I have a bad hip and drove the GS 1622 miles in three days from MacMulkin and another 1200-mile round trip last summer without discomfort. What constitutes an acceptable ride is subjective, but I'll wager that you'll love the GS.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Now have a Grand Sport that comes with mag shocks. I can validate what GM says is the ride stiffness comparision.
The base car with less stiff springs, small front sway bar, none in the rear and 36mm shocks is softest.
GM says the Z51 with mag shocks (assume GS is similar) set at Touring is next softest.
Next stiffest they say is the Z51 without mag shocks. I can validate the ride is somewhat softer in my Grand Sport than my Z51 when set at Toring-BUT not a lot!
Next stiffest is the Z51 with mag shocks set at Sport. I can validate that and although I like a firm ride and we have relatively good roads in Eastern SC I find the ride in Sport stiffer than I like so I drive mostly in Touring.
Siffest is the Z51 set at Track. I can validate what what one person stated. Set at Track you can feel if you go over a dime!
Your choice. For a long trip I prefer the wife's BMW X5 SUV for many reasons! Ride is good, less stiff than my Grand Sport set at Touring but most important I sit up high and can go over the many 18 wheeler tire treads on the Interstate without destroying a $1200 carbon fiber splitter! Buddy without a splitter wrapped one around a rear axle of his Vette! A lot of damage.
Love the Grand Sport for where I drive in our rural area where I can avoid the interstate! (It is a smooth ride on the Interstate, when I use it.) My 5th Vette. All have had HD suspension, would have nothing else-expect for long trips! Don't get me wrong it's not as bad as the CJ5 Jeep I had and about the same as the modified S10 truck with HD suspension relative to ride!
Recall a poster who unfortunately like many bought a Grand Sport because they liked the looks! He asked if he could change the suspension to that of base car! Best to trade for a base car! In addition, if getting a Z51 or Grand Sport be prepared to change brake pads as the dust from the OEM pads on my Z51 caused me to to switch to ceramic brake pads or I was cleaning he wheels every ~100 miles. They not only looked bad the dust was pitting my black wheels. Had no issue with the Grand Sport as I had ceramic pads purchased that I installed when I brought it home with 30 miles on the OD!
Just Sayn'! Unless you intend to push the car near the limit the base car handles just fine!
The following 4 users liked this post by JerryU:
I'll agree with you about the ride difference from first-hand experience, but not the part about the handling prowess of the base car. Even a base C7 without MRSC can reach skidpad numbers of >1G, which is better than 99% of cars on the road as well as most other sports cars. In fact, GM claims 1.0G for the base and 1.02G for the GS without Z07, and nobody will notice that difference. I've had both and can say that the base car has a very slight bit more lean in corners, but I never found the cornering to be anything other than stellar. The GS is snappier due to its wider tires and suspension tuning (tires, sway bars, etc.) with a ride that is comparable to a base car, IMO, but I would never say the base car is anything but an able performer in cornering.
The following 6 users liked this post by iclick:
JerryU (12-07-2017),
joemessman (12-07-2017),
silvertc6 (12-07-2017),
and 1 others liked this post.
Received 2,639 Likes
Never drove a GS. I did drive my base Stingray from Pittsburgh to S. Dakota, Wyoming, Colorado and back. Given the condition of the Interstates and various back roads we encountered I gained a healthy appreciation of the "soft ride" suspension. It handled better than my previous C6 Z51 (which handled great) and overall has more than enough power for passing or playing where conditions permit. Unless you are tracking the car and need a competitive edge, or insist on bragging rights over performance stats, there is no advantage to buying a GS for long distance travel.
The following 3 users liked this post by Rebel Yell:
I will most definitely be driving when temperatures are well below 40 degrees, even with some light snow at times. Therefore need to take tire availability into consideration.
Your statement above answers your question. There are no all season tires that will fit the rear wheels of the GS car (335/25x20). And there are run flat Michelin all season tires available. Everyone loves them.
https://www.corvetteforum.com/forums...-3-review.html
Looks to me like the decision has been made.
/thread
I have a 16 Base with Mag ride and a 17 GS. From inside the cabin, on a highway, it’s effectivley the same car. Depends on what you like the loloks of better. My base has no areo and averages 26 to 28 on highway. My GS with stage 2 was averaging 23-24 MPG on same stretch of highway. The difference readily becomes apparent once you decide to hit the brakes or try to go over a G in a corner. If your not tracking and not in love with the widebody look, you can save a lot of money! Side by side shows not a huge difference but the GS is definitely more aggressive looking.
Forgot to add, Base is a A8 and GS is a M7.
Received 2,225 Likes
I believe the ground clearance stock is the same.
The following 3 users liked this post by Walt White Coupe:
Your statement above answers your question. There are no all season tires that will fit the rear wheels of the GS car (335/25x20). The idea that the base car is for people that don't care about handling is rubbish. The base car (as said above) handles better than the Z51 C6 and that car was no slouch. The base car will ride the smoothest of all C7s. The brake rotors are nitrate hardened so they wear less, don't rust and the brake pads generate almost no dust. If you want a little better handling for ~$450 you can have Z51 sway bars installed.
Received 5,218 Likes
I can only speak to the base C7 and my C5. I bought the C7 nearly two months ago from Kerbeck's and drove it home (1600 miles) in two day. I found it surprisingly comfortable and much more so than my C5 coupe... much better seats, imho.
Also, the new run-flats (C7 base now comes with 19/20s) are SOOOOOO much better than the ones that came on the C5s, which I ditched soon after delivery. Current ones are surprisingly UNobnoxious on the highway under most conditions (well, apart from I-70 in eastern Indiana; worst roads of my entire trip home, but anything would be bad on it).
silvertc6 (12-08-2017)
#33
I absolutely notice the difference in handling between the base and GS. The lack of rear sway bar in he Base is very apparent to those who live for the tack. Best mod I did was add Z51 sway bars to my base. I personally could not stand the sloppy feel of the rear with no sway bar. I hated how it handled and still can’t believe a C7 comes without sway bars. If your not sliding sideways out of corners it’s probably a mute point. But there is a real tangible handing difference. I suspect most people saying otherwise don’t push hard in corners.
#34
Of course there’s a difference on a track. Most Corvettes, regardless of generation, have never seen and will never see a track. The OP is asking for advice about long pleasure trips, not track time.
The following 4 users liked this post by Steve_R:
#35
I had mag ride and now I have the base suspension and I can't tell a difference. It is nice to say you have it but if you need or want to save money I would ditch the mag ride.
Mag Ride is a must, it makes a significant difference and I wouldn't own a Corvette without it. I have had a Stingray with Mag, Stingray Z51 w/mag, and now a Grand sport which includes Mag. The Touring mode is very soft and enjoyable. But switching to sport or track you immediately feel like you're driving a sports car. Best of both worlds.
I believe I feel more of the road with the Grand sport than the other C7s.
#36
#37
#39
Had to throw in an edit. All that said, I love driving my wife’s base. It does not have the grip or brakes, but it’s actually just as fun if not more fun on the street, as it does not have my crazy track alignment, and turns in much more quickly. As a result, at a slower pace it actually feels “lighter on its feet”, and is more entertaining sliding around on a spirited street drive (with upgraded brake pads and Z51 sway bars). Point being, as others have correctly pointed out, if not on a track, pushing as hard as you can, you will love any C7. It’s an amazing platform, and I love all models. I park my cars next to Lambos and Ferrari’s and still find my eye drawn to the C7. Pick the model that suites your needs and you will be good to go. Long live the C7!
#40
I never plan to track my Corvette, so I bought a base car with M7. It has been great. I drive it hard and have thought about putting a rear sway bar on it.
One of the great things about the base Stingray is that it is a bit cheaper on maintenance, and less hassle with regard to things like brake pad dust.
On one level I would love to have the magnetic suspension, but I think active handling is too intrusive unless I'm in Track mode. With the mag suspension, being in Track mode would mean the suspension would be much too stiff for street use, meaning it doesn't deal with road hazards well (according to Chevy IIRC). The car really needs to let you choose your active handling setting separate from mag ride setting.
Since I have a 2016, I got to have the 18/19" tires which I prefer for street use. The slightly greater ground clearance of the base Stingray was/is desirable due to the ramp angle of my driveway apron. I don't know if the new Stingray still has the higher ground clearance.
FWIW. YMMV. LSMFT.
Whatever you decide on will be a delight.
FWIW. YMMV. LSMFT.
