C7 Drive Belt Dressing
Old Dec 17, 2017 | 04:25 PM
phatpipez's Avatar
phatpipez
Default C7 Drive Belt Dressing
Our salesperson mentioned including drive belt dressing in my C7 maintenance routine? Do any of you do that? If so, what do you use and how often do you apply it?
Old Dec 17, 2017 | 04:39 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
No. Never have on any car I’ve owned. In fact this is the first I’ve heard of recommending this for a Corvette.
Old Dec 17, 2017 | 06:41 PM
Avanti's Avatar
Avanti
Good luck putting it on evenly... check out the 11-pulley system shown in other posts. To put it into perspective I had the original belt on my C5 replaced after 16 years while replacing the failing crank-pulley assembly this summer.
Old Dec 17, 2017 | 07:14 PM
beaversstonehaven's Avatar
beaversstonehaven
No dressing for me except for Christmas dinner.
Old Dec 17, 2017 | 07:25 PM
04train's Avatar
04train
2022 C7 of the Year Finalist - Unmodified
St. Jude Donor '17-'18-'19
just make sure the dealer put synthetic blinker fluid in and you should be ok
Old Dec 17, 2017 | 07:38 PM
TEXHAWK0's Avatar
TEXHAWK0
Don't do it!
The GM service manual specifically says NOT to use any belt dressing on serpentine belts or it can cause deterioration.
Belt dressing was designed to prevent slipping of the old V-belts before automatic tensioners, not serpentine belts.
I do suggest you routinely check the belt for cracking, AND check the belt tensioner for signs of hydraulic fluid leakage.
I just had to replace my tensioner.
Note, the old serpentine belts only had ribs on one side of the belt. Now, the belt has ribs on both sides so it can drive pulleys on both sides.
That salesman must have gone to the same training school as the one that told my neighbor that once you put nitrogen in your tires, you can never go back to just using air..
Old Dec 17, 2017 | 08:25 PM
phatpipez's Avatar
phatpipez
What fluid do you use? Will it make my blinker blink faster?
Originally Posted by TEXHAWK0
Don't do it!
Thanks TEXHAWK0 for the information. I appreciate your input.
Last edited by Steve Garrett; Dec 17, 2017 at 11:24 PM. Reason: Merged Posts-Please use the Multi-Quote button (the middle icon) in the lower right hand corner to make your responses look like this!
Old Dec 17, 2017 | 09:07 PM
consolidated's Avatar
consolidated
sounds delicious, does it come with bits of drive belt?
To C7 Drive Belt Dressing
