Which fuel would you run?
Before I got my 2018 I was under the impression that the owner's manual in the Canadian spec C7s listed 91 octane as the recommended fuel, so I was all set to run both Costco 91 and Shell 91 in my 2018, both of which are ethanol free up here and Top Tier. But after reading my manual, I see that our cars up here also list 93 octane as the recommended fuel, but that you could run as low as 87 but performance will suffer.
So my question is, given the options that I have up here, what would you guys recommend I run? I could run the ethanol free 91, or I could also easily find Top Tier 94 octane at most Petro Canada stations here, but that has 10% ethanol in it. Will my performance suffer that much if I ran 91 octane? Or am I worrying too much about running a fuel with 10% ethanol in the first place? (either way, I would definitely make sure to run the ethanol free stuff for winter storage)
all we get is 93 octane with ethanol here it would not be a problem. OTOH the computer is set for 91 why run higher octane if not needed?
Being in California, we get both lower octane and ethanol. If I remember correctly, ethanol has a slightly lower flash point so does not give you the same explosion as with true gas. I am not a performance driver, by any stretch of the imagination, and I get all of the performance I want. Try the different fuels and decide which one you prefer.
Received 2,639 Likes
Pat, I run Shell 93 w/ethanol as a rule. But, if I'm on a trip and can't find Shell I'll use another top tier brand. As I understand the manual we should only use 87 in an emergency (if that's all you can find), and just enough to get you to a place you can get the 93. In my previous C6 I tried 93 non ethanol while on a trip. The mpg's were better, but not enough to make up for the increased cost of the gas. As far as performance with no ethanol I see no need to worry about that unless you're tracking your car. Modern engines are designed to run a 10%, or less ethanol blend.
dvilin (12-23-2017)
Rebel Yell (12-24-2017)
For an unsupercharged engine, the power difference for 91 versus 93 octane won’t be noticeable without a stopwatch. The mileage loss for 10% ethanol will be about 3%, or 1 mpg. Some people feel strongly about the politics of ethanol, but that’s your choice. All the fuels you mention are top tier, so that’s not an issue. There are no serious risks to ethanol for a modern car. Even if you store it over the winter, ethanol does not increase the probability you will have water separation. It only means that if you are unlucky enough to run into the circumstances that cause it, the problem will be slightly worse with ethanol. But a few bucks worth of stabilizer will prevent that from happening, so it’s not a killer issue. Just be sure that if you do store it with gas containing ethanol, you don’t use an IPA-based stabilizer like Seafoam. IPA-based stabilizers will not prevent water separation if ethanol is present. Bottom line is that none of the fuel choices you describe clearly and obviously beats the others. It depends on how you balance out the small power difference, the mileage difference, the price difference, and the politics of ethanol.
The following 3 users liked this post by LDB:
Thanks for your input! So now that I know I can safely run 91, I will seek out Costco whenever possible, but there is a Shell station a couple of miles from my house that I like as they price themselves about 5-7 cents less per liter than everyone else. There is a good chance I will take this car to the dragstrip from time to time, and for sure during those occasions I will run 94 octane just to be sure I'm getting little or no KR to spoil the fun
St. Jude Donor '10-'11-'12-'13-'14
I believe that all EU countries use the RON method of measuring octane, while the US uses (RON + MON) / 2. So your choices of 95 or 98 are equivalent to US ratings of 91 and 93.
I would not run less than 91 octane except for when there was no other choice.
Most modern fuel systems can now handle 10% ethanol with no adverse effects (like corrosion), and as you know the ethanol actually increases the octane rating. The disadvantage is that ethanol has a lower fuel value and your gas mileage will be less so you would be sacrificing fuel mileage for insignificant gains in performance.
Received 5,216 Likes
Go with the 94 and don't bother looking back... DRIVE & ENJOY!
This is a very picky point, but while ethanol does indeed have a high octane number (about 108), fuels are blended to the octane spec on the pump. So for example, a 91 octane fuel with 10% ethanol does not have higher octane than a 91 octane ethanol free fuel. The fact that the 10% ethanol fuel gets a boost from the ethanol is cancelled by the fact that it won’t have as many other high octane components. So from a performance standpoint, all you see from a fuel with 10% ethanol is the roughly 3% drop in mileage. There is no power gain from the ethanol’s octane since that is washed out in the blending process. The mileage drop is not washed out since ethanol contains less energy than the various normal gasoline blending components.
Patman (12-24-2017)
I've been running ethanol 10% in Corvettes for more than 700,000 miles - ZERO problems.... don't over-think this....
One caveat, once the knock sensor triggers a bit of spark retard, while the ECM keeps trying to go back to clean timing, that return to clean isn’t instant. I don’t know how quickly it drives things back, but if you’re serious about seeing the small 91 to 93 difference, you should probably run a few tanks of 93 to get ready, not just fill it up with 93 on the way to the drag strip.
When exactly was ethanol widely introduced in your fuel in the US? I know that they only first started experimenting with adding ethanol to fuel here in Canada around 1996 or 1997 but it wasn't really fully implemented until a few years after that.
I use the highest octane AND whatever TOP TIER gas station is around when I need to fill up. ONLY USE TOP TIER gas and forget about any type of additive! http://www.toptiergas.com/licensedbrands/
