I think you are talking about replacing the side markers?
If so, search for Oracle and you will find MANY threads on here with good detailed installation instructions, problems found (yes there are some), and even how to rewire them to turn them on with the engine is running or integrate them with the turn signals (European specs). They are easy to install without removing the fender.
no no...just adding LED strip lighting in the side intake..
Veloz, I've found that LED's in the grills make the car look cheap. Obviously, this is personal opinion, but you may Google C7 LED's and see what you can find out before spending the money on this mod.
