Hoodliner stains
Old Jan 18, 2018 | 04:59 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
I have had a custom painted hood liner in my Stingray for over three years with zero staining issues. When I wash my car, I do not rinse with water that is pressurized in any way. I wet the hood by letting water from the hose run over it, gently wash with a soft soapy mitt, then let the water run gently over the hood again to rinse.
No problems...
Old Jan 22, 2018 | 04:12 PM
auric22's Avatar
auric22
4th Gear
Default Hood liner spots
Originally Posted by 17KYC7
Well mine does this too. I’m still thinking it’s a seeling issue between the hood piece and the piece on the engine compartment. Really wanting to get my hoodliner painted but not until I figure this out. Surprised nobody seems to have had this problem and figured out how to correct it.
I am on my 2nd C7 hoodliner . I used ragtop cleaner & a brush on the first which cleaned the spots but shredded the cheap liner, Got a new one and sprayed tons of fabric protectent on the affected area - still have problem. Clear water and sponge not effective. Am thinking I need a spray over liner which will harden and seal the fabric so it can be washed easily with cleaner.
Open for ideas?
Old Jan 22, 2018 | 08:43 PM
spireland's Avatar
spireland
Originally Posted by Marcho Polo
the stains are usually soap in the liner. Spraying with hot water or a light pressure washer will get it out.
Thanks a ton. I've been annoyed by the "stains" on mine the entire time I've had my vette. Took a pressure washer to them this weekend, cleaned right up. I drive a lot, and wash it at least once a week, so there was a ton of soap in there. Worked like charm.
Old Feb 15, 2020 | 07:01 PM
2ndvett01's Avatar
2ndvett01
Just noticed under hood stains today. Used a damp microfiber cloth. Cleaned them quickly.
Old Feb 16, 2020 | 06:12 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
No stains on my on mine,but I don't pressure wash.
Old Feb 17, 2020 | 12:25 PM
Bob Beroza's Avatar
Bob Beroza
I repainted mine to get rid of the stains.
Old Feb 17, 2020 | 06:31 PM
BushN's Avatar
BushN
4th Gear
I pressure wash my C7 before and after using a foam cannon. I try not to pressure wash near the vent and let the water roll over it to rinse. I raise my hood after washing to dry the seams and while I have the hood open I take a microfiber towel and wipe the hood liner down where water or soap may have entered. This works well for me. If you let it dry and see a stain, you can take upholstery cleaner(3m, Turtle Wax) and clean it off. This also works well.
Old Feb 17, 2020 | 06:51 PM
sTz's Avatar
sTz
I never had an issues as I always lift the hood and dry the engine bay after washing, but I bet Scotchgard, or a similar product, would minimize staining... or at least make it easier to clean
