I need touch up help.
Old Jan 31, 2018 | 10:39 AM
EASonBASS's Avatar
EASonBASS
Originally Posted by rmorin1249
EASonBAss, did you apply only a small amount to the chip or did you apply enough to completely fill it and then wipe down the area to make it smooth? Once the weather warms up I have several to fix on the front of my car. Thanks.
Enough to completely fill, then gently wiped down. Repeated until full coverage. Go very gently on the smoothing, particularly the last couple passes to keep the coverage. BTW: I'm not an expert, just my experience with this same shallow and wide ding. I also used the recommended DR CC method on a couple tiny, deeper spots and it was pretty effective on those. You can experiment as the Sealac will remove the paint completely until it cures.
