Airbrush Paint Chips?
Can you airbrush out paint chips and get good results --- or is it better to just go after them one by one with Doctor Color Chip?
Is the question can YOU do, it or can IT be done?
Just remember that chips are small craters, and paint is really thin. So you really need to fill the crater if you’re going to spray paint.
The following 3 users liked this post by rrsperry:
Dr. Color Chips is certainly not the end all be all. While I have used the product, I found that I can get perfect results from just touch-up paint sanding (2000 grit), DA w/compound, polishing, and buffing. Can’t see why airbrushing wouldn’t work if done by someone who is experienced. You’ll still have to polish and buff...
I simply don't know and thought I would ask ...
I just got one of these for the inevitable paint chip and it looks like it will work nicely when I need it.
You just fill the small reservoir with matching paint and place the needle like tip in the chip/crevices to fill it with paint.
I use one of those for watercolors/ink.
The paint would have to be REALLY thin to work with this. Not thinking this would be an ideal tool for the job. Acetone will work to thin the touch-up paint, however.
Let us know how it goes. And don't lose the cleaning wire.
Not the best way but in a pinch old body shop trick you can use the end of a match using touch up paint - to do it right you would have to go the whole nine yards - repair - primer - base and then clear coat no way around it to do it right - would wait till its gotten worse before investing to do it correctly
You do have to thin the paint though to about ink consistency which is not difficult to do.
@ about 4:30 into utube
Received 19,305 Likes
'20-'21-'22-'23-'24
Thanks for posting these ideas.
Kevin - where did you get that device? And please post up how well it works.
eta: you can get everything from there, anymore. I would also like to add (having used this tool for other purposes and dealt with plenty of touch up paint for cars using other tools) that alcohol will not clean this tool. You will need acetone or other type of paint thinner. The man in the video was using a touch up paint that was not the same as our cars use.
Bandit1 (02-02-2018)
Thanks for the guidance and info! I might try it just to see how it works out --- but on some test plates first before I go after it for real.
I was thinking about this being a possibility at about the same time I was considering it as a possible way to refinish metal headed golf clubs. A guy can pick them up almost anywhere for very little --- and it seems like a neat way to bring them back to life.
Received 2,225 Likes
This is what I've always used to thin and clean brushes with touch up paint.
In answer to the original question, many dealers and high end detail shops have people who "airbrush" minor paint repairs. When done by an experienced person, the results are excellent and nearly undetectable. I am not sure it would be cost effective for a single owner to buy the necessary equipment for personal use.
The following 2 users liked this post by JALLEN4:
JimNeedsC7 (02-02-2018),
Range_Rat (02-02-2018)
I just had a chip (2) happen on my GS, after pondering which method to use I chose Dr Color Chip again, color was spot on and the little squeegee they provide worked well. I used a broken round toothpick to apply the paint then pulled it into the chip as directed, did it a couple of times to fill it, followed their directions and very pleased with the result Not perfect, if any ever are, but perfectly acceptable to me. Good luck
NSF
NSF
Patience is the key!
Dr.Colorchip is nothing more than THEIR Touchup paint with a couple Gimmicks to sell,Period.
You need to match and Fill to look right.
Some need glasses and think it looks good.Some got lucky with exact amount,in the hole of chip.
Key is,In the Hole..Probably do coats
The following 2 users liked this post by DALE#3:
C82LT (02-03-2018),
Kevin A Jones (02-03-2018)
Dr. Color chip works wonders and I always get a kit for every car I own. I have never been disappointed. Sometimes you have to go back to fill in deeper pits but still works wonders.
