Pinging?
Old Feb 1, 2018 | 10:25 PM
helirich's Avatar
helirich
Default Pinging?
My wife's early 16' C7 is making a sound. To me it sounds like bad gas. But she has changed the gas several times. (Always premium)
The sound comes in when your cruising around 45-60 and you hit a slight hill in a high gear. My wife thinks that it only started after she had the torque converter replaced last year. (A8) The new TC fixed allot of issues, but not sure if this related. We just got the car back from the dealer for tires, this and other sounds. They told us the sound is normal lifter sound.
Unrelated sound, cracking sound from roof panel. They said they lubed the roof. Can't tell a differnce. Any suggestions?
Old Feb 1, 2018 | 10:29 PM
owc6's Avatar
owc6
Take it to a dealer to be diagnosed?
Old Feb 1, 2018 | 10:55 PM
Walt White Coupe's Avatar
Walt White Coupe
I don't know what it is but you can safely rule out pinging and bad gas.
Old Feb 1, 2018 | 11:10 PM
helirich's Avatar
helirich
Did you not see the part where I said we just picked it up from the dealer? They said it was lifters.
Old Feb 1, 2018 | 11:15 PM
owc6's Avatar
owc6
Yep, I guessed I missed the part where the dealer said it was normal.
Not sure why you're still questioning the sound, then. And then you want guesses from here?
If you want a guess: If it sounds like a sewing machine, it is normal.
Or if you still don't think it is normal, take it to another dealer. You might get another answer from them.
Old Feb 2, 2018 | 04:34 PM
helirich's Avatar
helirich
It sounds like a slight exhaust leak. Or bad gas. In any case, I wasn't looking for guesses, I was looking for someone that had a similar sound that got it fixed.
Old Feb 2, 2018 | 04:58 PM
Walt White Coupe
Then you better provide a better description of the sound you are hearing or even better a sound recording so we can hear it for ourselves.
Old Feb 2, 2018 | 05:05 PM
Bavaria's Avatar
Bavaria
Perhaps shifting to a lower gear may help.
Old Feb 2, 2018 | 05:16 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
All you'll get is guesses when asking about a noise that we can't hear.
My best guess is that it's the fuel injector "pinging" sound, which has been described as similar to a sewing machine sound. I seriously doubt that it's the old-school "pinging" from preignition or detonation in the cylinders.
Old Feb 2, 2018 | 05:52 PM
dash7510's Avatar
dash7510
This might a stretch but maybe you are hearing the dreaded warble noise. If you hear it at the tall tail rpm of 1500. Do a search on this forum for warble.
Old Feb 2, 2018 | 06:08 PM
BobFic's Avatar
BobFic
If your prognosis is guessing what it may be, move on to another dealer,set your appt. that you want to speak to Vette Tech, tell him what issues are happening and he needs to go for a cruise (ride) with you and have him hear/feel what the issues are. Good Luck
Old Feb 2, 2018 | 06:14 PM
helirich's Avatar
helirich
It does. But my wife does not manual shift. I'm wondering if the tranny can be programmed to stay in a lower gear. Has anyone heard of this?
I will have to do some research on this. Thanks.
Old Feb 2, 2018 | 07:06 PM
NSC5's Avatar
NSC5
A lot of engines are programmed to stay right on the ragged edge of detonation in a number of driving situations so I wouldn't be surprised if she is getting some slight ignition ping. I noticed that my 2014 ATS (3.6 direct injection) would do this at moderate speed on moderate grades because the transmission is programmed to shift to the highest range possible for best fuel economy and this can put the engine in a near lugging situation.
True heavy knock will create an immediate reaction by the ECM to deal with it but this light "spark knock" she is experiencing may not be considered significant enough to result in timing retard. In the few situations that caused the problem with my ATS I just downshift it manually, I have never noticed this with my 2016 Z06 but it gets nothing but 93 octane except for a couple of tanks of 91 just before winter storage since that is the highest grade ethanol free in my area.
Old Feb 2, 2018 | 09:18 PM
Walt White Coupe
Has anybody heard of a knock sensor?
To Pinging?
