Z06 Trunk dimensions
Old Feb 4, 2018 | 12:27 PM
davis5233's Avatar
davis5233
2nd Gear
Default Z06 Trunk dimensions
I need the width and height of the trunk since we will be picking up the vehicle in a couple weeks and I need to know how to pack
Old Feb 4, 2018 | 01:53 PM
Kevin A Jones's Avatar
Kevin A Jones
Convertible trunk or coup back hatch area?
Old Feb 4, 2018 | 10:11 PM
Seldoon's Avatar
Seldoon
I have a convertible. I don't know the exact measurements but it is certainly small.
Old Feb 4, 2018 | 10:22 PM
Kevin A Jones
The GS/Z06 convertible trunk will hold two typical size rolling airline carry-on bags and still have space for additional items on top.
Old Feb 5, 2018 | 08:25 AM
davis5233's Avatar
davis5233
2nd Gear
Thank you so much. This photo was worth a thousand words. It's huge by my standard. I was told to pack light but it's actually quite spacious. You're a love!
Old Feb 5, 2018 | 02:16 PM
Kevin A Jones
While not near as much space as a coup, there's more space than you think when you start loading the vert trunk up. To be more specific, it
measures approx 49"x16"x11".
Old Feb 5, 2018 | 02:36 PM
JoesC5's Avatar
JoesC5
49"X16"X11" equals 4.99 cubic feet.
GM specs are 10 cu ft cargo space for the convertible(15 cu ft for the coupe).
The C6 convertible also had 10 cu ft cargo space.
I wonder where the discrepancy is.
Old Feb 5, 2018 | 03:13 PM
defaria's Avatar
defaria
One reason why I didn't go with a convertible is that I need to be able to carry multiple guitars:
Old Feb 5, 2018 | 05:17 PM
Kevin A Jones
See my above photo. My dimensions are for the trunk compartment with rear partition up/fastened. GM is including the area behind the partition where the convertible top is stored when down. If top is up, there's additional usable space in that area not shown in my photo.
I typically keep my partition up and fastened as the top mechanism will lower the top if not up and fastened.
Old Feb 5, 2018 | 06:13 PM
Jim Barker's Avatar
Jim Barker
There is even more room in the vert with top up and partition down. Three to four cloth grocery bags more can be shoved or stuffed there!
Old Feb 5, 2018 | 10:42 PM
xwing's Avatar
xwing
Way smaller than the C5. My only real gripe about the C7. There were many things I was able to carry in my C5 that I cannot in my C7 (both coupes).
To Z06 Trunk dimensions
