Tire question
Old Feb 10, 2018 | 10:14 PM
ojm's Avatar
ojm
Default Tire question
Just out of curiosity can run flats be switched to conventional tires without the low profile flat looking run flat tires? Do conventional fit to a C7 design would you need smaller rims. TIA
Old Feb 10, 2018 | 10:18 PM
Jmhornz71's Avatar
Jmhornz71
just replace your runflats with non runflats of the same size its not a problem
Old Feb 10, 2018 | 10:22 PM
ojm's Avatar
ojm
Thanks , does that mean a" taller" rubber wall conventional tire?
Old Feb 10, 2018 | 10:24 PM
Jmhornz71's Avatar
Jmhornz71
They will be exactly the same its just that sidewalls arent as stiff as with the runflats every measurement is the same
Old Feb 10, 2018 | 10:28 PM
Skid Row Joe's Avatar
Skid Row Joe
The "conventional" tires, are the same dimensions as the ZP run flats. Did you think they were different sized??
Old Feb 10, 2018 | 10:35 PM
owc6's Avatar
owc6
Run normal pressures and they will look the same.
Get a flat and all bets are off.
ojm's Avatar
ojm
I don't think my question was understood. I like the looks of sidewalls that don't have low profile like my older sports car. Is that doable?
That is why stated if need to go too smaller rims not sure how the tires would fit in the wheel well area. For example could you use wide tires like on a 74 vette? I guess also would effect speedo.
Old Feb 10, 2018 | 10:39 PM
Foosh's Avatar
Foosh
Not likely . . . "tall sidewalls" don't come in 19-20" sizes. You'd have to purchase a set of smaller diameter wheels, but then you'd have to worry about finding a set that would fit over the rather large C7 brakes calipers.
Old Feb 10, 2018 | 10:42 PM
ojm's Avatar
ojm
Originally Posted by Foosh
Not likely . . . "tall sidewalls" don't come in 19-20" sizes. You'd have to purchase a set of smaller diameter wheels.
Thanks, that was the part was asking also.
Skid Row Joe
*to
Go to a Discount Tire store, or it's equivalent tire store near you and ask away. When you start messing with the tire height on a low profile, low fender opening as the C7 has, you're bound to run into trouble. Esp. if you think you want a taller profile tire. Can you do it? Sure. Should you? Doubtful.
owc6's Avatar
owc6
The speedo and odo should read the same as OEM as long as the resulting diameter is the same. Whether the (smaller) rim can handle the brakes is another issue.
eta: don't you love when you get several answers virtually identical w/I a minute or two?
Old Feb 10, 2018 | 10:52 PM
Skid Row Joe
^^^^ After messing with various cars and tires/wheels for over 50 years, experience, as well as trial AND ERROR, count for something!
Old Feb 11, 2018 | 12:16 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep, thought that was what you were asking. You can probably get more like a '74 look if that is what you are wanting for whatever reason! In fact wider rims can be used on "skinny tires" (within reason) and it actually improves handling! Go to Tirerack and check out tires of the same diameter but higher profile. Should find some.
Quick look and I found a 235/45/19 for the rear that has a diameter of 27.3 which is close enough to the OEM 26.7 OD 285/35/19 OEM's! 285-235 = 50 mm = ~ 2inch narrower section width.
To Tire question
