Friend just crashed his Supercharged ZO6
#101
It's both brakes AND accelerator slammed to the floor, as illustrated in this video. This car might have ALL nannies turned off...
BTW, one of my favorites is GP (good point).
Maxie2U (02-22-2018)
#102
This "brakes AND accelerator" slammed to the floor technique seems like a little more than I'd be willing to put my car through. Must be tough on the rear brakes and maybe a little tough on the torque converter and drivetrain.
Thanks for the lesson.
Regarding "GP" -- thanks again for defining it. IWHNGWIMO. (I would have never guessed what it meant otherwise.)
#103
There is definitely something missing or at least more to the story here because a) I've felt nannies kick in on sport 2 and b) there are still some nannies in race (though, not much). I'm not sure I've noticed any difference in throttle sensitivity, but that's not to say there isn't a difference.
edit: With all respect to Bill's opinion, why would it say reduced engine power instead of throttle progression like it does in the chart right above it for non PTM modes?
Actually, I’m unsure if my own comment above is precisely correct. AH works by “small individual brake and engine torque applications”. So, if you are doing a burnout, that implies you have the brake pedal slammed to the floor. I’m unsure if AH can then add any additional braking to the corresponding wheel where it is needed (if the car starts to fishtail). This would be a GQ (good question) for the engineers that developed the system. And, considering how often owners do burnouts, a GQ for owners to know the answer to.
Another test would be to turn off TC, and, leave on AH. Then, on wet pavement, floor the accelerator. The rear wheels should crazy-spin, but AH should intervene to keep the car pointed how you are steering it.
Obviously, don’t actually try any of this here, or, “somewhere in Mexico”.
It is called a line lock. People that drag race install them all the time. Some mfg's are including them now such as mustang, challenger, etc. As I recall, there was a big issue because Ford put it on the car, but then voided warranty if you used it on a drag strip.
driver9 (02-21-2018)
#104
The TC doesn't do much for the Z. It snaps so fast you have to start correcting before you hammer the pedal. The car will loop even with TC and in some cases by the time it intervenes it makes things worse. I run it in our wonderful 30F weather with TC off and try to get a better feel for what this snap monster is doing. My ZL1 is much easier to feel and predict.
LATSWATDA...(let's agree to stop with all the dumb abbreviations).
JHEBERT (02-22-2018)
#105
It takes some serious effort to spin a c7 with nannies on.
#106
Spinning it is easier in cold temps. It is 16F here at noon today. So wonderful.
Another factor that can contribute to crashing these things in a scenario that the OP posted about, is the eLSD. When you turn nannies off, the eLSD is still doing it's fancy business for which no one seems to know the algorithm. In a fishtail scenario with yaw pitch changing rapidly the eLSD could misjudge, and cause additional oscillation. I have experimented with this too. Also, the car could have a malfunctioning eLSD and never throw a code so GM doesn't know how to fix it. I have experience with this too.
So the OP's friend could claim the car malfunctioned. Who could prove otherwise?
#107
#108
The nannies are very good at controlling the Z when someone pushes it a little too far but they are designed to ASSIST a reasonable driver and not make the world safe from a total moron. If you try to enter a hairpin turn on the Tail of the Dragon at 140 MPH you are past the point where anything can control the vehicle (well anything except the solid rock side of a mountain). If you accelerate a little too hot with cool tires on a cool surface it will get you back in line. But if you nail the throttle on cold tires on a crowded street you are likely to be into something before the control systems can unwind your stupidity. The torque from a Z06 will result in behavior you won't generally see with a naturally aspirated or even the typical turbocharged engine which won't have the near instantaneous availability of diesel engine like low RPM torque.
Remember, the slang term for these protective systems is "nanny" and not God. Like a children's nanny they help keep children in line but they can't always overcome a determinedly stupid adult.
The following 6 users liked this post by NSC5:
AORoads (02-22-2018),
BlackMamba89 (04-24-2018),
Foosh (02-22-2018),
JerryU (02-22-2018),
kenownr (02-22-2018),
and 1 others liked this post.
#109
Well said.
#110
Yes, it's traction control, not traction boost. All it can do is manage the traction you have, not add additional traction. It can straighten you out or cut throttle when you are on the gas too hard, but it can't add more front grip when you're lead footing the brake into a turn you took too hot.
With that said, it's hard to **** up a drag race with AH on.
sunsalem (02-23-2018)
#111
She just had the oil change, it’s broken in
5500mi now and runs like a raped ape
#113
more importantly, I learned I can actually have numerical gauge readouts instead of some stupid ******* gauge that is impossible to read. Tour mode will be my new track mode.
#114
The numerical readout on the track gauge is a plus for buying an 2018.
#115
Received 8,961 Likes
You need to know how to drive and considering that 99.99999% of US drivers have no clue what that means there is a lot of trouble when they get behind the wheel of a car that does what they tell it to do when they tell it to do it. Even when they didn't mean to tell it to do what it is doing.
Bill
#116
Don't know why they can't update the 17's.
#118
I know, as soon as I turned the dial to Track mode on my new '18 and saw that numerical readout of all important parameters, Track display mode became my all-the-time setting regardless of driving mode.
I'm also using Track/PTM Wet as my almost all-the-time winter setting in daily driving since it keeps MSRC in Tour mode and it keeps both TC and ESC fully engaged. It is remarkable how it only puts down the right amount of power to prevent wheel spin, without being intrusive.
