Overheating
Old Feb 27, 2018 | 05:18 PM
SRQStingray's Avatar
SRQStingray
Default Overheating
After 49,000 miles with no big problems, my Vette started overheating. Temp went up to the red zone at a light. I pulled over, shut down, waited awhile and drove home with windows open and heat blasting. Checked coolant and reservoir was very low. Got in my SUV and went to parts store for Dex Cool. Put in 1/2 gallon. Drove to work, 25 miles on interstate, no problem. Dealer called and said to bring it in. Temp rose to 250 in traffic. Again, windows open, heat blasting. I don’t think the fan is coming on. Normally, it is easy to hear. Fortunately, I bought a long extended warranty a few years ago. I’ll update when I hear back from dealer.
Old Feb 27, 2018 | 07:22 PM
ersatz928's Avatar
ersatz928
Sounds like a bad fan motor, or fan control module.
Old Feb 27, 2018 | 07:32 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
What year car?
Old Feb 27, 2018 | 08:25 PM
SRQStingray
Originally Posted by eboggs_jkvl
what year car?
2014
Old Feb 27, 2018 | 09:05 PM
robert miller's Avatar
robert miller
Robert
Old Feb 27, 2018 | 09:20 PM
GOC's Avatar
GOC
But he said the coolant was very low. Maybe a leak somewhere or a bad thermostat and leak there?
Old Feb 27, 2018 | 09:31 PM
ersatz928's Avatar
ersatz928
Or it spewed-out coolant from the pressure relief valve in the cap when it was overheating.
Old Feb 27, 2018 | 09:41 PM
DALE#3's Avatar
DALE#3
After you get it back and we all know things are ok
Sure you know (that trick with heater on)Gonna have to really Baby sit the coolant level.
Old Feb 28, 2018 | 04:52 PM
SRQStingray
Just heard from the dealership. The water pump was leaking. The part is over $800. I have an extended warranty, but also have time left on my powertrain warranty. I think it is covered under powertrain. In addition, a belt tensioner is leaking oil,. That part is $300. I'm hoping that too is covered.
Old Feb 28, 2018 | 04:57 PM
eboggs_jkvl
Moderator emeritus
Sounds like good news with the extended warranty in your pocket. That would bite me hard in the wallet without an extended warranty. I hate surprises!
Elmer
Old Mar 2, 2018 | 02:23 PM
SRQStingray
I misunderstood, part and labor for water pump was over $800. Part and labor for belt tensioner about $300. Since I still have powertrain warranty, water pump was covered. My extended warranty covered the belt tensioner, but I have a $100 deductible. My final cost was $107 because of 7% tax in Sarasota county. Hopefully, everything is copacetic.
Old Mar 2, 2018 | 04:17 PM
HAD2HAV2's Avatar
HAD2HAV2
SRQ be glad a new pump will cure your over heating problem. Others overheat because of a suspect fan / computer problem. I have the Extended also. At those prices, looks like I made a wise decision.
Old Mar 2, 2018 | 04:47 PM
ONENATION's Avatar
ONENATION
Lucky you! Hope that cured the problem.
Old Mar 2, 2018 | 06:01 PM
VictorBarron's Avatar
VictorBarron
Count me in for being glad that I got an extended warranty. Peace of mind.
To Overheating
