Nail in tire
Do you think Chevrolet do this repair with mushroom type plug? I can see my local dealership.
I just wanted a patch but they insisted on the patch/plug. I worked at a tire shop when I was a kid. The wooden wheels were much tougher not to mention split rim truck tires.
Received 2,225 Likes
https://www.hunter.com/wheel-balance...SAAEgLjhfD_BwE
Flo (03-19-2018)
Dealers usually don't have the latest tire machines and don't have nearly the experience. They will also try to sell you a tire. Go down and talk to the Discount Tires guys. The only thing I worry about is proper jacking. Ask them if they have jacking pucks.
I recently picked up a screw in one of my rear Z51 tires. I've plugged several tires before, but these were a serious PITA. Not sure if it's the thickness of the steel belting or what, but it took me quite a while to file the hole enough to allow the plug to be inserted.
It's been about 2.5 weeks so far, and no leak. $8 Slime plug kit at Wally World, along with a round bastard file I had in the tool box and about 30 minutes of work.
Flo (03-19-2018)
To avoid damage under the car?
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
I used this kit on my 2014 Z51 Stingray and it held full air till I traded it in on my 2017 Z06. I would not hesitate to use it again if I got a nail in the tire again. As long as the nail is somewhere near the middle of the tire and not the sidewall you are all set for this kit. It is very very easy to use. Just check your DIC to make sure your tire is holding the air after you plug it. Good luck.
robertbruce (03-23-2018)
"Xactly! The plastic body panels extend below the jacking points. Very easy to crack and very difficult to repair once cracked. They are probably already familiar with Corvettes but doesn't hurt to double check. Take a look in your owners manual to show you where the jacking points are. Each one has a little oval hole in it.
#33
Thank god no split rim truck wheels are on the road anymore. We used to have a steel cage to inflate tires mounted on those type wheels but about once a month or so kaboom !
You could just see employee moral disappear whenever a truck with split rims came in ... not good, even the counter guy was a little freaked out.
#35
Yeah something has to fill in the hole so normally they put a plug in it, then cut it off inside, buff accordingly and glue a patch inside. Same thing almost with those mushroom looking plug/patch repairs.
#36
DynaPlug
Worth every penny. This plugged three holes in my OEM tires with no leaks for over a year. They didn't see track duty so no need for new tires.
My first attempt was to take it to a local Pep Boys that mounted the tires on my other car with no problems, but after they wouldn't listen to me about using the proper lift points for fear of cracking a rocker panel I drove away from there as fast as the fun flat (with a slow leak) would allow.
#37
I've seem farmers and other old timers just loop a chain around through the center of the assembly and bolt two links together, but I was happy to have the cage available for me. I was told that when a typical truck tire with 100 psi (which is typical) comes off a split rim, it does so with enough force to blow a 16 pd bowling ball 1/2 mile, or a 3 thousand pound car 15 feet off the ground. Sort of explains why they were so dangerous.
#38
DynaPlug
#39
You are a brave man.
#40
I've plugged them in the past, but never on a tire this difficult. I might have to look for that cool kit that was posted.
