Ceramic Brake Pads
Old Mar 20, 2018 | 07:44 AM
EyCandy's Avatar
EyCandy
Cruising
Default Ceramic Brake Pads
Hi Everyone, Have you replaced your brake pads with ceramic? Which brand did you use? I have heard of Hawk and Tru Stop. They will be put on a Grand Sport.
Old Mar 20, 2018 | 08:10 AM
shakinrock's Avatar
shakinrock
With my C6 (and plan to do the same with my C7 Z51) I used AutoZone Gold ceramic. Those that track their car or are purests will criticism me but they functioned just fine. I did all 4 corners for under $100 (dealer wanted $1100+, just pads).
Great how to on this site!
Old Mar 20, 2018 | 08:35 AM
Kracka's Avatar
Kracka
PowerStop is one of the more popular choices on the C7 for aftermarket pads. They have both ceramic and semi-metallic pads available.
https://www.powerstop.com/products/#...Brake%20Rotors
Old Mar 20, 2018 | 10:37 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
If you want a quality aftermarket pad I recommend the Carbotech 1521 pad 100% made in the USA. A low dust pad that is rotor friendly and performs like OEM and last longer. 100% non-corrosive dust will not harm your paint or wheels. This pad also contains NRS technology. Carbotech uses NRS technology on all C4, C5, C6 & C7 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested I will be happy to help you out or you can order online here http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out for your 5% discount.
ZO6/GS part numbers.
F: CT1405
R: CT1718
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To Ceramic Brake Pads
