Triple flush differential
Old Mar 22, 2018 | 07:54 AM
Steve9235's Avatar
Steve9235
Default Triple flush differential
Does anyone know in detail what that means when you take it back to the dealer that they want to do a triple flush differential thank you
Old Mar 22, 2018 | 07:58 AM
Kracka's Avatar
Kracka
Triple flush is for the A8 transmission. No reason to do anything more than a simple drain & fill on the differential.
Old Mar 22, 2018 | 05:15 PM
orca1946's Avatar
orca1946
Will that be needed on my soon to be delivered 2019 GS? And at what mileage?
Old Mar 22, 2018 | 05:26 PM
Steve9235's Avatar
Steve9235
Miles 2700 base a8 2017
Old Mar 22, 2018 | 11:07 PM
Luke42_02's Avatar
Luke42_02
St. Jude Donor '17
They hook it up to a pump and fill the transmission, lines, and cooler then pump it all out, then fill and empty 2 more times. Tripe flush worked on my 2016 at 15k miles. At 20k now, still good.
Old Mar 22, 2018 | 11:56 PM
Bill Dearborn's Avatar
Bill Dearborn
Depends on how you use it. Normal Service Schedule says rear axle at 45K. Severe Service Schedule says 45K miles for both A8 and Rear Diff. Track duty drivers diff change to every 24 hours of track use. Might give you an idea how much more stress track duty places on a car Vs even spirited driving on the street.
Bill
Old Mar 23, 2018 | 08:43 AM
Steve9235's Avatar
Steve9235
Did you have the noise and after the flush was it gone
Old Mar 24, 2018 | 09:53 PM
tcinla's Avatar
tcinla
How much does it cost if you are under warranty?
Old Mar 24, 2018 | 10:11 PM
Steve9235's Avatar
Steve9235
Under warranty
Old Mar 24, 2018 | 10:43 PM
Joy c7's Avatar
Joy c7
You said it had the warble noise its the Diff, Will need to be replaced.
To Triple flush differential
