How to Replace a C7 Corvette Water Pump (Video)
Over the weekend, I picked up a faint new engine noise with the motor at idle; over the next 100 miles or so it got a little louder, so I popped the hood this morning to check it out. The noise was even louder, sounded like a ball bearing going bad so after I shut it down, I started to check for play in the drive pulleys. Sure enough, the water pump had close to 1/4" of side play....not good.
Next I check the Forum for others who have experienced the same problem; I found one member who said the dealer wanted $500 to change it out ($250 was parts), needless to say, that was like taking a hand full of little blue pills! I got real motivated at getting the job done with my own two hands! As it turned out, it was like…. WAM-BAM, Thank ya Ma’am, and I was done. It took about 15 minutes to remove all the plastic & rubber parts from of the TB forward and then a couple minutes to figure out how to collapse the hydraulic belt tensioner (to get the drive belt out of the way). After that, drain the radiator, remove the 6 bolts (10MM socket) from around the water pump and BINGO, the biggest part of the job was in my hand.
I tried looking for a U-Tube video on how to remove the water pump on a C7 and found none….so after finding how easy the job was, I thought I would make one for the next Shade Tree mechanic.
The following 22 users liked this post by hisvett:
767guy (03-24-2018),
badhabit_wb (12-31-2018),
beaversstonehaven (03-23-2018),
cowboy casey (11-14-2019),
devnull (03-24-2018),
and 17 others liked this post.
Awesome job. Torque specs for the pump bolts might be a nice addition to your video. I've learned to use my Torque wrenches a lot more lately.
Just a thought.
Just a thought.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Very good video! Clear and good advice. Thanks.
Great job OP, thanks for sharing with us. We need more DIY videos like this in our community.
How many miles did you have when it went bad? I wonder what is the average lifespan for these in our cars. BTW, did Chevy not want to cover it under warranty?
