2017 LT1 automatic poor shift
Old Mar 26, 2018 | 10:19 AM
Johnseeds's Avatar
Johnseeds
2nd Gear
Default 2017 LT1 automatic poor shift
Mostly when the automatic transmission is still cold it shifts poorly from 1st to 2nd (normal or slow acceleration). All other gears shift smoothly. Florida car.
Old Mar 26, 2018 | 10:21 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
My friend experience the same problem, and took it in for oil change they updated the computer with new software which solved the problem.
His only complaint is why did GM wait this long to get it right.
Old Mar 26, 2018 | 06:04 PM
C5Driver's Avatar
C5Driver
Unfortunately its a very common issue of the poorly engineered 8 speed transmission, Usually goes away once warm.
Old Apr 4, 2018 | 07:03 PM
thrilled's Avatar
thrilled
I’ve been hearing tranny withA TC aren’t nearly as quick with auto’s without it.
This is just what I read.I stick with the M7.Using the no lift shift procedure i’m nearly as quick as the auto.
Old Apr 4, 2018 | 07:06 PM
dr4carz's Avatar
dr4carz
Wonder if Chuck Cow tune will help. Give him a call.
Old Apr 5, 2018 | 05:50 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Always does!
Always does!
I always use the latest TCM software that I know works.
Honestly, don't call me if you're just looking to fix a trans bug that a GM update will fix. If you're not
local to me, it's not worth the trouble.
ON THE OTHER HAND.... If you want the problem to go away AND make the car into a monster.....
Here's my number..... 914-332-0049
Chuck CoW
Old Apr 5, 2018 | 07:00 PM
C5Driver's Avatar
C5Driver
Try getting the Range AFM disabler it not only holds the car in v8 mode all the time but improved my cold shift points by 75%
Old Apr 5, 2018 | 07:19 PM
Kevin A Jones's Avatar
Kevin A Jones
Yep, shifts smooth a silk
Old Apr 6, 2018 | 12:03 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default That's one of the MANY things we do in our tune.....
In addition, AFM control and my modified converter lockup / unlock schedule GREATLY improves the drive ability
of the A8 Automatic Corvette.
Chuck CoW
Old Apr 6, 2018 | 12:35 PM
davepl's Avatar
davepl
What's a "poor" shift versus a "smooth" shift I wonder?
Old Apr 6, 2018 | 12:42 PM
iclick's Avatar
iclick
Often the 1>2 shift can be helped by a simple software reset to readjust adaptive learning. Back when I had my 2015 A8 many were complaining about the same issue that was rectified by following the attached instructions. This is an old doc, so you might check to see if a more current one is available.
Old Apr 6, 2018 | 12:54 PM
bills2017's Avatar
bills2017
I have a 2017 Stringray that shifts poorly, badly what you want to call it only when its cold once it warms up everything is great. What do I tell my dealership when I take in for service is there a service bulletin for repair.
Old Apr 6, 2018 | 02:38 PM
Flame Red's Avatar
Flame Red
I have a '15 and the tranny got swapped with 100 miles on the clock. I have the same delayed 1 - 2 shift when cold. Goes away really fast since in the Florida inferno the thing warms up really quick. I guess I just got used to it. Just revs a bit on the first shift. By the time I get to the end of the block the thing warms up enough that it shifts fine. When I start it I let it idle for 30 seconds before I put it in drive so I don't get the lunge that sometimes occurs if I do not.
The Range has NO impact on this behavior. I had a range it it forever. The engine is not going to go into 4 cylinder putt-putt mode anyway till it is warned up. It is not going to be in V4 mode in first gear.
As far a an aftermarket tune, I would stear clear. If you have the prominent TC issues and GM finds an aftermarket tune, you will probably be on your own. If you are out of warranty, tune away!
I'll assume you are on a B2B warranty. If it really bugs you, take it in and the dealer will check if there is a newer flash available. Maybe they will try the triple flsuh with the newer fluid if the 17 don't have that.
Old Apr 6, 2018 | 04:15 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default ALL software updates and Adaptive RESET procedure.
You should ask them to perform ALL software updates and Adaptive RESET procedures.
2015 Cars in particular have MANY software updates for the trans and you would have the best shot at
addressing your concerns by having them.
Additionally, we have had a few modified 2015 A8 cars that caused me headaches for an entire year to resolve shift complaints
when driving easy and after what amounted to 60 or so re-flashes the problem was still NOT resolved.
Fast Forward, I created a custom A8 tune for the 2015 A8 Cars that now works PERFECTLY regardless wether
the vehicle is STOCK or MODIFIED.
The primary complaint was a very hard SLAM SHIFT slowing to a stop.....
All fixed now, but YES requires my tune and AutoCal package.
Chuck CoW
To 2017 LT1 automatic poor shift
