Electronic feedback/static
Old Apr 2, 2018 | 05:24 PM
Stevied's Avatar
Stevied
Default Electronic feedback/static
2015 3LT Base Coupe has intermittent buzzing sound/static. This happens regardless of whether the radio is off or on. Sounds like it is coming from the electronics. Car has Navigation, etc. as 3LT package.
Old Apr 2, 2024 | 02:49 PM
C8aStang's Avatar
C8aStang
Cruising
My 2016 3LT is doing the same thing. Even after I shut the car off, I still hear it until I open the door. Did you ever find out what was causing it?
Old Apr 3, 2024 | 11:43 AM
76-Vetteman's Avatar
76-Vetteman
Interesting! Never heard any noise like this. Loose ground somewhere?
Old Apr 3, 2024 | 04:40 PM
C8aStang's Avatar
C8aStang
Cruising
Not sure but it is definitely the small speakers in the door. Guess I'll pull the panels and look further into it. Don't understand how speakers can put out static sound even when the radio is off. Maybe the car has been bugged!! LOL!
Old Apr 4, 2024 | 10:53 AM
westsdad's Avatar
westsdad
Try pulling fuse 21 in the rear compartment fuse box. It's for the amplifier which will help narrow things down.
Old Apr 4, 2024 | 11:35 AM
calvins's Avatar
calvins
Oldtimer
Sure sounds like a bad ground. Let us know how you make out.
Old Jul 1, 2024 | 07:19 PM
FL-355's Avatar
FL-355
JefferyFrame is on to something. Understand run-flats (have them on other cars) and type of road you are driving on. I live in same area as the OP. First Vette 22 Z51. Real bad road noise. DB meter would hit 91 on the freeway. Two trips to dealer and can't figure it out. Fast forward a year later and took delivery of 23 ZO6 with bigger tires and she runs quiet like a Benz (except engine symphony of course). Both cars HTC. 2 cars, same conditions, one loud as heck and the other quiet. JefferyFrame makes sense and if I had the problem I would look there first.
To Electronic feedback/static
