Door locks
Old Apr 12, 2018 | 03:54 PM
Dan Dlabay's Avatar
Dan Dlabay
Default Door locks
I have a 2017 vette and I would like to set the door locks up so that when I exit the car the doors automatically look and I hear a chirp signaling that the alarm is set and I can't open them unless I have the fob with me. My C6 was set up to do this.Can I set this up on a C7?
Old Apr 12, 2018 | 04:03 PM
IAIA's Avatar
IAIA
Easy. Check out page 132 in the (2017) owner's manual under Vehicle Personalization through the Settings menu in the infotainment system. (Not sure all cars have this. Check your owner's manual.) It's called Delayed Door Lock. I have it set all the time.
"Delayed Door Lock
When on, this feature will delay the locking of the doors. To override the delay, press the power door lock switch on the door. Select Off or On."
Coupled with Remote Left in Vehicle Alert," you can't be locked out.
Old Apr 12, 2018 | 09:54 PM
Itz4func7's Avatar
Itz4func7
2nd Gear
Default Auto Door Lock on C7
Quite Simple
Go to Settings
Select vehicle
Select lock unlock option
select passive door lock
select on with/without horn
it will lock about 20-30 seconds after the door is shut and you walk away
Horn will sound
to test, approach the car WITHOUT key fob. Doors are locked. Just like the C6.
Unfortunately there are several who say this cannot be done but it was easy to do.
Old Apr 13, 2018 | 08:41 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
That's how I have mine set up. Never need to remove the fob from my pocket.
Old Apr 13, 2018 | 12:23 PM
orca1946's Avatar
orca1946
That is how my C6 was and I will do the same on the 2019 GS.
Old Apr 13, 2018 | 03:10 PM
Walt White Coupe's Avatar
Walt White Coupe
I've tried the procedure described here on my 2016 and I can't get it to automatically lock. It was very easy on the C6.
Old Apr 13, 2018 | 03:18 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Don't make me drive up there and set it for you!
I set my '14 to autolock w/o horn. The option is there Walt try again with the manual in hand this time and not the beer!
Elmer
Old Apr 13, 2018 | 04:55 PM
Rebel Yell's Avatar
Rebel Yell
Walt, I worked, cussed, and tried many times to set the auto locks on my '16. Nothing. Then I thought, hell I'll start the engine to see if that will help. Bingo.
I've got another car that you need to have the engine running just to set the dang clock. That's why I thought about starting the motor.
Old Apr 13, 2018 | 07:35 PM
Walt White Coupe
Well, I've tried every possible combination and there aren't that many combinations and mine just doesn't work. I'll have to have the dealer check it out sometime in the future.
Old Apr 14, 2018 | 07:43 AM
Dave80C3's Avatar
Dave80C3
Set this up on my 2014 Stingray, quick and easy. FOB never left my pocket for lock or unlock. First thing I did when I picked up my 18 Grand Sport.
To Door locks
