Having the engine idle
Old Apr 15, 2018 | 11:36 PM
Foosh's Avatar
Foosh
I don't think a little surface rust inside the cylinders, if in fact it does happen, makes any difference. You don't see brake rotors rusting unless they are put away wet, and even then the surface rust is gone with a few brushes of the brake pads. They are far more exposed to the elements than a relatively sealed engine.
I don't know what "subtle degradation" you might be referring to here for a car that sits for a few months. Sure, an engine that sits for several years may well need some attention before trying to restart, but even those are routinely brought back to life with a little internal lubrication before trying to start them.
Old Apr 15, 2018 | 11:38 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Starting it for a few minutes 2 or 3 times a year won’t hurt anything in your lifetime.
Old Apr 15, 2018 | 11:40 PM
owc6's Avatar
owc6
Yep, because if that's all you do to it, you'll die before the car does.
Define lifetime.
Old Apr 15, 2018 | 11:44 PM
Foosh's Avatar
Foosh
That's also true.
My question was what "preventative maintenance" benefit do folks think they gain by doing so? It seems some actually think it's a good thing to do that.
I get it that a kid or perhaps even you are bored and might want to hear the engine, back up and down your driveway a few times because you're going stir-crazy, and that's a good reason to do it. But, if you're doing it because you think it's helping the engine, I don't get that.
Old Apr 16, 2018 | 12:08 AM
blb078's Avatar
blb078
I start my cars up over winter. It's to move them because I don't put anything under the tires, I let them warm up to normal temps and shut them down. Usually I'm out getting the mail, pulling the trash/recycle cans, walking around the house to make sure nothing is messed up etc. while it's all going on. Lubrication, bearings, etc, etc, all this stuff is so advanced that everything is more than well coated. I've stated in another thread, I've never heard of anyone say their engine crapped out on them because they started it up over winter a few times, or that their engine crapped out on them because they didn't start it up over winter. It's such an insignificant thing as to whether which ways is good/bad, better/worse that it wont matter either way. As someone else said you may get 200,000 miles instead of 202,000 miles.
Old Apr 16, 2018 | 12:19 AM
Steve_R's Avatar
Steve_R
RF radial tires don’t flat spot over a few months so that’s not a reason to start it up and move it either.
Old Apr 16, 2018 | 12:30 AM
Foosh's Avatar
Foosh
OK, I get that. It gives you something do. But, I think it's probably the reverse, you'd get 202K miles by not doing it, vs. 200K by doing it.
Old Apr 16, 2018 | 12:32 AM
blb078's Avatar
blb078
I don't care, I'm still doing it. Do it on all my cars that sit over winter regardless of what the tires are, regardless of what people say is good/bad for the engine. When I have or hear of issues from doing it then I'll stop but I'm pretty sure that I'll never have/hear of any issues. And my C7 I don't do it because mine is a daily driver and get's driven over winter except when ice/snow is on the ground then I take my truck.
Old Apr 16, 2018 | 12:36 AM
blb078's Avatar
blb078
Oh, Right you are!
Old Apr 16, 2018 | 12:40 AM
Steve_R's Avatar
Steve_R
Good for you. I live in western Colorado and my C7 is also driven year round unless there is snow or ice on the roads. I feel a bit sorry for those who let them sit for months and depreciate while they’re not enjoying them.
