How the flip do I turn [TP] off???
Old Apr 18, 2018 | 10:05 AM
jimxms's Avatar
jimxms
Default How the flip do I turn [TP] off???
I have a Euro spec z51 with nav, and in the top left of my media screen is a [TP] icon. What this means is that whenever a local FM radio station decides to broadcast travel updates it interrupts whatever I’m listening to, ramps up the volume to 11 and I get a nonce telling me that a road 50 miles away is closed.
Clicking the icon does nothing, I’ve looked through every menu including the satnav ones but there are no options to turn it off!!!
Its driving me nuts. Help
Old Apr 18, 2018 | 11:43 AM
Foosh's Avatar
Foosh
I'm stumped. Never seen that before and no idea what it means.
Old Apr 18, 2018 | 12:14 PM
Jeff V.'s Avatar
Jeff V.
I don't really have a solution for you. All I can suggest based on some time on Google is that it's not a "setting". It's more of a notification. It's just telling you that station carries traffic programs. Does it change to TA when the station plays a traffic announcement?
It may not be possible to turn it off.
Old Apr 18, 2018 | 12:18 PM
UsernameProtected's Avatar
UsernameProtected
People still listen to broadcast radio?
Old Apr 18, 2018 | 12:24 PM
Jeff V.'s Avatar
Jeff V.
This is kind of a long shot, and it seems really obvious, but I figured I'd pass it along anyway. I found this in an Opel FAQ about the 2015 IntelliLink system. That's just another name for the MyLink system in Chevrolet branded cars.
Q: How can I enable or disable radio traffic announcements (“Traffic Programme”)?
A: To enable or disable traffic announcements, tap on "Menu" on the audio main screen and then change the setting of “Traffic Programme” accordingly
Source: http://www.opel.com/content/dam/Opel...0_20151028.pdf
Old Apr 18, 2018 | 12:45 PM
jimxms's Avatar
jimxms
Interesting. I’ve looked at all of the settings within the various screens (radio/media/satnav) but not the main screen. I’ll check it out in a little while. Thanks
Old Apr 18, 2018 | 12:46 PM
jimxms's Avatar
jimxms
In the U.K. FM radio is still very popular. DAB is gaining traction, but it’s only been standard on most cars for a couple of years
Old Apr 18, 2018 | 12:51 PM
jimxms's Avatar
jimxms
The TA icon is always on screen. Normally it’s something that can be turned on/off in the settings (like on my Mercedes).
To make matters worse it was’t enables when I bought my car, it’s only since I cut the battery while installing my supercharger that it has switched on.
Its infuriating though. Imagine cruising around, roof off, with your tunes blaring. Then all of a sudden at maximum volume, some dork starts reading the traffic news. Aaaaarreghhh
Old Apr 18, 2018 | 01:01 PM
Jeff V.'s Avatar
Jeff V.
Yeah, that does sound annoying. I hope it's in the main audio menu. Let us know how it turns out.
Old Apr 18, 2018 | 03:37 PM
Avanti's Avatar
Avanti
It's just someone's way of telling you that you should be driving a "home-built" car in the UK.
Old Apr 18, 2018 | 04:07 PM
jimxms's Avatar
jimxms
I may have been born and raised in the UK, have a UK passport and drink lots of tea, but my love is for everything American
The Astons, Jaguars made in China, and the Bentley's made in Germany can all go themselves
Old Apr 18, 2018 | 04:45 PM
Mike in IA's Avatar
Mike in IA
If it is like some other things I have noticed on several other cars - if you adjust the volume WHILE the alert is on, that will change the sound level for THAT function. No guarantees.
Old Apr 18, 2018 | 05:28 PM
redman76's Avatar
redman76
St. Jude Donor '09
Great suggestion
Old Apr 19, 2018 | 01:13 PM
jimxms's Avatar
jimxms
Still no joy with working this out.
On the main screen this is all I get from clicking on the options:
All of the major FM radio stations seem to have TP signals, the only one that didn’t was a pirate station.
Even if I switch to listening to digital radio the TP logo remains and
it will switch to an FM station broadcasting traffic news all the time!!
If I cant find out how to stop this I may need to resort to cutting wires. AM/FM should have a separate antenna to Digital radio I would think?
Old Apr 19, 2018 | 04:40 PM
Zymurgy's Avatar
Zymurgy
Moderator
Try the following on the Infotainment Screen: While on FM station, > Menu > RDS - On. That will toggle RDS to Off.
Old Apr 19, 2018 | 05:02 PM
jimxms's Avatar
jimxms
I did give that a try, but the TP icon remained. I can't recall whether I got any traffic updates after turning it off though - I'll give it a longer test tomorrow. What I did notice though is that RDS turns its self back on
Old Apr 19, 2018 | 05:08 PM
Zymurgy's Avatar
Zymurgy
Moderator
I think the icon is just letting you know that the station has the information broadcast. Turn it off again and see if the updates stop. Don't know why it turns itself back on again. That shouldn't happen. You mentioned that it started the updates after you had your battery disconnected. You might want to try resetting the system to factory defaults and/or disconnect the battery again for at least 10 minutes. The reboot may resolve the problem. Factory default is probably On, so turn if off after the reset and see if it stays that way.
To How the flip do I turn [TP] off???
Old Apr 19, 2018 | 05:16 PM
jimxms's Avatar
jimxms
Thanks, I'll give it a go. I wonder if RDS can be disabled in Tech2. Might be something I will need to explore if it refuses to stay off.
Old Apr 19, 2018 | 10:00 PM
Jeff V.'s Avatar
Jeff V.
Tech2 doesn't work on the C7. You need an MDI (or clone) and the GDS2 software.
Old Apr 19, 2018 | 10:53 PM
defaria's Avatar
defaria
You can stop the traffic announcements by hitting the Media button...
