Oil % question
However like all of my 5 Vettes it tells you to change a minimum every year! But this is the first Vette that keeps track of time for you!
Checked my '93 Owner's Manual that says for normal driving change at 7000 miles or 1 year whichever occurs first.
It also says if most trips are less than 4 miles change every 3000 miles or 3 months!
I too was unaware that the oil has to be changed each year regardless if under the 7500 miles recommended interval.
The probability of something happening is very low but the cost of a failure is very high. I make sure I have the records to back up that I have followed the GM required maintenance.
But IMO there's some leeway when it comes to changing the oil, or not, after 12 months.
A few extra miles isn't going to hurt anything.
But it depends on how the car is driven and for how long it is driven each time the engine is started during a 12 month time.
Multiple short trips, less than 20 miles each time is bad for oil life because the oil will not get hot enough, "for long enough", to burn off water condensation etc in the engine when it's fired up.
This causes acids/contaminants etc to build up in the oil and sit there until the next engine start.
Driven that way the Oil Life Monitor % will go down faster than normal regardless of time elapsed, driven or not.
That's its purpose and how it works.
Putting the car away for winter and changing the oil without starting the engine is not a problem IMO.
Spring comes and the OLM % is down low with Clean oil is one thing.
But a car driven only short distances for short periods a few times "after" an oil change, and then put away for the winter, is something else.
I don't start my Vette unless it's going to be driven at least 40 miles or more for the day.
And pretty much use it as my DD in the Summer, but not for short errands, unless I'm going to continue driving it many more miles afterwards.
Changed the oil/filter last year 05-05-2017 right before driving from MA to FL and back, with more miles put on after returning home.
That was 85-90 % highway miles.
Changed the oil 3 months later on 08-10-2017 when the OLM % hit 25% with 4,850 miles on the oil change.
Today 04-27-2018 almost 9 months later and 2,875 miles the OLM is at 25%.
If I wait, 08-10-2018 will be 12 months since the last oil change and OLM will hit 0% on, or before then.
When I've checked oil level before each oil change, the level is still where it was when filled from the last oil change.
And the oil still looks good on the dipstick, although it looks black when it's drained
It's cheap insurance to change the oil and I get ready to change it shortly after the OLM hits 25%.
I also have to decide when to change it earlier if it's close to putting it away for winter, or near 12 months since the last oil change.
It helps in certain situations deciding when to change the oil or not, to consider how the car is driven.
a 2008 Uplander and rather than disposing the oil, I change the oil in the Uplander since it's out of warranty anyway and add the lightly used (1500 mile) C7 oil and go 3K on it in the Uplander. They want us to recycle, so I recycle.........I also have a 2003 Honda Accord I can use 4 quarts in when it's time.
Odd how they make all the claims and brag about the qualities of the synthetic oils yet you have to follow a procedure that was changed causing the owner to abide by the rules or suffer the Wrath of Khan.
Throw common sense out the window along with the baby and the bath water and forget trying to make any sense of this issue.
And you don't HAVE to change the oil when the DIC says. If you think you know better, then do your own thing, but then you have to take responsibility for the consequences.
However, if you want the factory warranty, and have the factory take responsibility for damages, then you have to abide by the rules set by the factory.
Seems so simple, and yet some people want to play by their own rules, but still have others take the responsibility.
I buy from Walmart, 5-30 dexos approved Mobil 1 for $25 for a 5 quart jug. I buy two for the dry sump.
I scan the receipts as that is all Mobil requires for the $12 rebate per jug (two allowed.) So I pay $2.60/quart and the whole job is done in much less time than going to the dealer!
AND I am sure:
My rocker panels are not cracked form improper lifting,
The oil isn't overfilled,
It is really Mobil 1,
The fitter is not over tighten nor are the two drain plugs.
Plus I look at the magnets on the drain plugs I installed at the 500 mile oil change!
