Vert Trunk Latch Recall?
Old May 5, 2018 | 11:12 PM
jtranger's Avatar
jtranger
Default Vert Trunk Latch Recall?
Third time my Vert top (2016) has not been working. Dealer replaced the top latch twice and top is not working again today. The top and trunk latch are on the same circuit. Is there a recall on the trunk latch? I was going to inform the dealer to check that since they can't get to the bottom of it.
Old May 5, 2018 | 11:26 PM
Avanti's Avatar
Avanti
https://www.corvetteforum.com/forums...h-2017-gs.html
Old May 6, 2018 | 09:28 PM
BELVIN20's Avatar
BELVIN20
There is a recall, it came out several months ago. Had it done to my 2016 Z Vert.
Old May 7, 2018 | 09:50 AM
VH Vette's Avatar
VH Vette
My 2016 Trunk failed to open. I cycled the Top up and down and then the trunk opened ok. Had Recall done on Trunk and no problems since. Never had problem with Top not operating.
Trunk and Top are tied together so you cannot operate the Top with the trunk not completely closed.
I have not removed the Trunk shield that keeps cargo away (or not blocking) Top. There is some sort of protection switch so that the Top is not operated if it is not installed properly.
Hope you get it fixed. Top down season is here.
VH
Old May 7, 2018 | 12:46 PM
jtranger's Avatar
jtranger
On my third try here with the dealer to correct this
Old May 7, 2018 | 04:48 PM
Rebel Yell's Avatar
Rebel Yell
He's going to needed to plug it in to a computer to reprogram one of those dang compooters as I understand the process. Took all of approx. 15 minutes for my dealer.
To Vert Trunk Latch Recall?
