GM vis
Old May 6, 2018 | 05:43 PM
halp's Avatar
halp
Default GM vis
Could someone please send me a VIS on 1G1YE2D7XE5124996
Old May 7, 2018 | 10:06 AM
robertbruce's Avatar
robertbruce
I don't know what year you have but here goes 1, built in US. G, General Motors. 1 Chevrolet. Y Y body. E, 3LT Manual Transmission, 2, Coupe. D, AJ7 Active Manual Belts Airbags Driver Passenger and seat side. 7, Engine LT1. X Check digit 0 to 0 or X ?. E, Model Year. 5, Plant Bowling Green. Last numbers are production numbers.
Old May 7, 2018 | 07:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
A GM VIS is a report from GM's computer systems (Vehicle Inquiry System - VIS) that will list a bunch of information about the vehicle. This is much more detailed that just decoding the limited information that can be deciphered from the VIN.
Here is one pulled on my C7 shortly after I picked it up at the NCM:
Vehicle Information
VIN: 1G1YL2D7XE5113194 Model: 1YX07-2014 CORVETTE
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: M11WW2WT XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Chevrolet 2 Year Scheduled Maintenance 01/24/2014 3 MI 01/24/2016 24,003 MI
Powertrain Limited Warranty 01/24/2014 3 MI 01/24/2019 100,003 MI
Bumper to Bumper Limited Warranty 01/24/2014 3 MI 01/24/2017 36,003 MI
Emission Select Component Ltd Wty 01/24/2014 3 MI 01/24/2022 80,003 MI
Corrosion Limited Warranty 01/24/2014 3 MI 01/24/2020 100,003 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
02/07/2014 E5113194 ZPDI----Pre-Delivery Inspection 0590072 - Pre-Delivery Inspection - Base Time 5 MI
02/07/2014 E5113194 ZREG----Regular Vehicle Transaction 0590116 - CORVETTE MUSEUM DELIVERY - FUEL ALLOWANCE 5 MI
02/07/2014 E5113194 ZREG----Regular Vehicle Transaction 0590106 - CORVETTE MUSEUM DELIVERY PROCESS 5 MI
Vehicle Build
Model: 1YX07-2014 CORVETTE Order Number: RBKQBN
Gross Vehicle Weight: 1,818 Build Date: 01/23/2014
Build Plant: 5
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SZ - PREFERRED EQUIPMENT SAVINGS 3LT - 3LT PREFERRED EQUIPMENT GRP: * MEMORY PACKAGE * SEAT ADJUSTERS, POWER BOLSTER & POWER LUMBAR * SEAT, CORVETTE LOGO BADGE * NAPA LEATHER SEAT INSERTS * LEATHER WRAPPED AND COLOR KEYED INSTRUMENT PANEL CONSOLE & DOORS * CONVENIENCE NET & LUGGAGE SHADE, TRUNK * POWER HEATED OUTSIDE MIRRORS ADJUSTABLE, DRIVER SIDE AUTO DIMMING * INSIDE REARVIEW MIRROR, AUTO DIMMING * HEATED & VENTILATED SEATS * UNIVERSAL HOME REMOTE * PREMIUM BOSE AUDIO WITH 10 SPEAKER SURROUND * ADDITIONAL 9 MTHS XM RADIO * ADVANCED THEFT DETERRENT SYSTEM * HEAD-UP DISPLAY, COLOR * CHEVROLET MYLINK NAVIGATION
556 - BROWNSTONE 55I - INTERIOR TRIM JET BLACK BROWNSTONE
5A7 - WHEEL SPARE 6X1 - COMPONENT FRT LH
7X1 - COMPONENT FRT LH 8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP
9L3 - SPARE TIRE 9X2 - COMPONENT RR RH
AAB - MEMORY PACKAGE AG2 - PWR SEAT ADJUSTER, DRIVER & PASSENGER
AJ7 - AIR BAGS, FRONTAL AND SIDE IMPACT WITH PASSENGER SENSING SYSTEM AJK - SEAT ADJUSTERS, POWER BOLSTER & POWER LUMBAR
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AP9 - CONVENIENCE NET, TRUNK
AQ9 - SEATS, BUCKET, LEATHER SEATING SURFACES AXJ - VEHICLE TYPE PASSENGER CAR
B4Z - PERFORMANCE TRACTION MANAGEMENT BGR - BOWLING GREEN PLANT
C2Z - REMOVABLE ROOF PANEL, VISIBLE CARBON FIBER WITH BODY-COLOR SURROUND CFX - PLAQUE, PERSONALIZED WITH CORVETTE MUSEUM LOGO
CJ2 - AIR CONDITIONING, DUAL ZONE CLIMATE CONTROL D42 - LUGGAGE SHADE & PARCEL NET
DD0 - POWER HEATED OUTSIDE MIRRORS ADJUSTABLE, DRIVER SIDE AUTO DIMMING DD8 - OSRV
E2C - ORDER TO DELIVERY - EXPEDITE EF7 - COUNTRY UNITED STATES OF AMERICA (USA)
FAY - CARBON FIBER INTERIOR PACKAGE FE4 - MAGNETIC RIDE CONTROL W/PTM PERFORMANCE TRACTION MANAGEMENT
FE9 - 50-STATE EMISSIONS FHO - VEHICLE FUEL GASOLINE E10
G7H - LAGUNA BLUE TINTCOAT G96 - DIFFERENTIAL, ELECTRONIC LIMITED SLIP
GU6 - REAR AXLE 3.42 RATIO I14 - ENGINEERING MODEL YEAR
IL6 - SUEDED MICROFIBER SEAT INSERTS IWE - SUEDED MICROFIBER-WRAPPED UPPER TRIM PACKAGE
J55 - BRAKES, PERFORMANCE 4-WHEEL ANTILOCK, 4-WHEEL DISC J6E - CUSTOM CALIPER COLOR - YELLOW
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT KNP - TRANSMISSION OIL COOLING SYSTEM
KNR - COOLING SYSTEM AXLE KQV - HEATED & VENTILATED SEATS
LT1 - ENGINE, 6.2L V8 DI/VVT MAH - MARKETING AREA US, PR, USVI
MEL - TRANSMISSION, 7-SPEED MANUAL WITH ACTIVE REV MATCHING N38 - STEERING COLUMN, POWER TILT & TELESCOPIC
NP5 - LEATHER WRAP STEERING WHEEL NPP - EXHAUST, MULTI-MODE PERFORMANCE
NT7 - FEDERAL EMISSION SYST TIER 2 Q7T - BLACK PAINTED ALUMINUM WHEELS, 19" FRONT & 20" REAR
R8C - CORVETTE MUSEUM DELIVERY (INCLUDES PERSONALIZED PLAQUE WITH CORVETTE MUSEUM LOGO) CORVETTE MUSEUM LOGO R9N - PROCESSING CODE - SEAT
R9Z - POMS EXPEDITE - SOLD ORDERS RAO - CHEVROLET MYLINK WITH 8" COLOR TOUCH SCREEN, BLUETOOTH AUDIO
ROO - BARS VOMS BAILMENT SLL - SOLD ORDERS
T4F - HEADLAMPS, HIGH ÉINTENSITY DISCHARGE, XENON, LED PARK AND TURN SIGNALS TTV - CARBON FLASH PAINTED SPOILER & OUTSIDE MIRRORS
U2M - HD RADIO UE1 - * 6 MTH ONSTAR(R) DIRECTIONS ÉAND CONNECTIONS W/AUTOMATIC ÉCRASH RESPONSE, TURN-BY-TURN ÉNAV & 5-YEARS REMOTELINK APP ÉKEY FOB SERVICES (ASK DEALER ÉABOUT GEOGRAPHIC COVERAGE).
UG1 - UNIVERSAL HOME REMOTE UHS - DRIVER INFORMATION CENTER
UQS - PREMIUM AUDIO W/ SURROUND UTJ - CONTENT THEFT ALARM, THEFT DETERRENT SYSTEM
UTT - ADVANCED THEFT DETERRENT SYSTEM * CONTENT THEFT ALARM, THEFT DETERRENT SYSTEM UTU - SENSOR, VEHICLE-INCLINATION
UTV - SENSOR, VEHICLE-INTERIOR MOVEMENT UV6 - HEAD-UP DISPLAY
UY4 - CHEVROLET MYLINK NAVIGATION SYSTEM V8D - VEHICLE STATEMENT - US
VA5 - ENGLISH LANGUAGE LABEL VH9 - ENVELOPE OWNER INFO MANUAL
VRG - VVA/COMPONET REL COCKPIT VRH - VVA/COMPONET REL STEERING COLUMN
VRJ - VVA/COMPONET REL POWERTRAIN DRESS VRK - VVA/COMPONET REL ROOF TRIM
VRL - VVA/COMPONET REL FRONT HORIZONTAL SUSPENSION VRM - VVA/COMPONET REL FRONT VERTICAL SUSPENSION
VRN - VAA/COMPONET REL REAR SUSPENSION VRR - VAA/COMPONET REL TIRES & WHEELS
VT7 - OWNERS MANUAL ENGLISH VZE - MODEL YEAR 2014
XFJ - RUN FLAT TIRES XL8 - FREQUENCIES RATING 433 MHZ
Z51 - PERFORMANCE SPORT HANDLING Z52 -
To GM vis
