After 7500 miles in my 2017 C7 GS A8 I seem to have contracted the TC virus. Noticed it on a recent long trip, this fluttering feel to the car but wasn’t sure if it was just a bumpy road. After getting some ideas on here I tested the car in auto at 65mph constant speed in V4 mode and the rpms oscillate about 80rpm. In manual and V8 mode at the same speed there is no oscillation.
Not keen on having GM pull the back of my car off to experiment with resolutions by replacing my TC. Also I don’t think it would be good at trade in (4-5yrs time) to have it on the service record. So I’m seriously considering buying a Range module and leaving the TC as is.
Am I right in saying with the Range module installed the TC no longer comes into play and I’m not at risk of TC failing completely and getting the shudder which is probably the next phase if I don’t do something?? I don’t want to delay the onset of the problem by going with the Range module.
After rolling my eyes at all the people bragging about the Range module I now seem to be next in line. I was more than happy for it to go in V4 mode if it improved efficiency when the power was not required.
Had the flush followed by a new TC and 4 miles later back in the shop waiting for factory comment to dealer. Meanwhile I am making monthly payments and driving a Malibu.
I'd recommend getting a Range before issues show up. As I understand it, the shuddering feel is slippage in the TC that is beyond its design. The TC is supposed to slip some during V4 mode to reduce vibration, I think, and this is the source of the problem. Wonder what the M7 drivers feel since they don't have a TC. The patch kit for the problem is a triple flush with a less slippery fluid. But hasn't damage been done by this time? The fluid is a bandaid.
I believe Tadge said in an ask post that no functional changes have been made to the TC. The newer part numbers seen available are due to manufacturing changes rather than fixes for performance or reliability. If that's correct then your 2019 TC is functionally the same as my 2015 TC and is susceptible to the same problems. With that knowledge in mind I'd say get the Range before you need it.
My '15 A8 went about 25k miles before I noticed anything. I've had the triple douche and so far it feels OK. I've added a Range so I never use V4 mode. Time will tell.
We here on the forum are not a good example of the general ownership population in that we openly share our problems here. If I (and likely others here) wasn't reading how other owners are feeling a shudder in their cars and that it is a problem then I might not notice it in mine. Or maybe I'll figure its normal and not take it to the dealer. As it is we're all listening for warble in the rear and feeling for shudder in the TC. So our failure rate may be higher than the average owner not associated with a forum or club simply based on our awareness.
I would have the TC replaced and then use the Range module to prevent further issues. If I were looking at purchasing your car down the road, I would have a PPI done, test drive it, ask if you had had any issues with the TC and if they had been resolved. If you don't address the issue prior to offering it for sale, you risk having the potential buyer exposing an expensive known issue that may or may not be covered under the warrantee at that point. This could greatly affect the car's resale value or crash the deal. Another alternative is to not get it fixed now, use the Range module, and get it fixed prior to sale or before the warrantee runs out. Just some food for thought.
I remember reading somewhere that a highly trained GM Tech said the RPM wavering is common due to the very active TC. I believe he was speaking at a Corvette Bash a yr or so ago, can't remember for sure. Just saying not sure if this info was accurate or just GM jargon. I too am close to ordering a range device. I have noticed some RPM movement but no shudder and drive 95% in manual mode but that is a little aggravating in town. As U guys know it is hard to get the car into a situation where you don't see some RPM movement, several things can affect RPM, speed, hills, gear change, even cruise control. I am like some other guy posted, I am very aware of the slightest thing due to reading the forum posts daily, LOL. Just my thoughts.
Simple put my friend the Range won't fix your TC. But, if as you say it doesn't act up while in V8 mode the Range will keep it out of the V4 mode. And, the mpgs aren't affected that badly.
Does the range void warranty? How is it installed?
The Range Unit just plugs into the obd connector under the dash on the left side by the kick panel . It does not alter the tune in any way and only stops the AFM from kicking in but ... as always if there is any doubt about voiding a warranty you should unplug it before taking the car in for any work ......
Thanks for the input so far. I’ve put in an order for the Range Module and driving in manual mode. Thinking I will do the triple flush and then just use the Range Module from there on.
My advise to new buyers is to get the Range Module from day one and give the AFM the boot. I’ve done a full 180 on the need for a Range Module could not understand the need before.
Our '15 Z51 with 4,000 mile experienced the RPM wavering. To tell if you have an issue, you can head to a nice flat section of interstate. When you get to a spot with no traffic in front of you, put it in Touring mode, and engage the cruise control (If you have a Range device installed, remove it first). Watch the tach. It should not move at all. If it wavers, then you have an issue (ours did). You do not have to wait long as it should be evident almost immediately. I took it to the dealership and had a triple flush done. I drove home on the same section of interstate and had no waver. Once I got home, I reinstalled the Range device and its been there ever since.
The range seems like the best, cheap (<$200) way to give A8 owners peace of mind. Have there been any cases where the TC failed while the owner was using range?
