Help Needed - Hard Brake Line
Hello Guys,
i need your help.
i noticed a leak of oil in the hard brake line, near the driver side / rear section of the Car.
In attached you can see a part sheet (of a C6 Corvette) that shows the part i would need (N°4)
that are the twin pipes that goes all the way from the ABS pump in the front, to the rear.
can someone plaese suggest where order? or find a code of that part?
(i cannot get to the dealer, i live in Italy and we do not have corvette dealers or parts dealers.. so i will have to purchase from US)
i have a 2014 C7 Z51 pack M7.
Thanks!
Alessio
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Hmm, because of the length for shipping and procurement difficulty you could consider having a local quality shop make one! I need to do that for a rear line on my Street Rod just haven't gotten around to it.
Sure hope mine is the line fitting and not that 1960's Caddy caliper that incorporated a parking brake. Caddy only had it for two years as it mechanically activated the disk brake piston. Useless!
Received 8,930 Likes
Sure hope mine in the line fitting and not that 1960's Caddy caliper that incorporated a parking brake. Caddy only had it for two years as it mechanically activated the disk brake piston. Useless!
I agree a local shop should be able to fix the brake line by splicing in a new piece and using the proper fittings to hold a seal on a brake line. A lot simpler than trying to order one from the states with the risk of having it get damaged during shipping.
Bill
JerryU (05-25-2018)
