Front Splitter
Old May 26, 2018 | 02:12 PM
Bob Beroza's Avatar
Bob Beroza
Default Front Splitter
i have a question for you guys.
I have a chance to get an original factory front splitter from a 2017 Grand Sport. Will it fit my 2015 Base Stingray?
Do I need to make any modifications to make it fit or is it a plug & play?
Let thank you in advance for any help!
Old May 26, 2018 | 03:25 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Plug and play.
Old May 26, 2018 | 09:15 PM
sTz's Avatar
sTz
Yes, plug-and-play. You’ll just need the additional fasteners... The OEM is attached w/screws and 10 rivets that had to be drilled out.
Old May 26, 2018 | 10:25 PM
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
If you want to go back with OEM-style rivets to match the factory install, I found this source on ebay when I installed my Stage 2 Splitter...much less expensive that getting them from the dealer:
https://www.ebay.com/itm/Rivet-GM-Pa...item234f77a504
Old May 27, 2018 | 02:56 PM
TEXHAWK0's Avatar
TEXHAWK0
If you add splitter to base Stingray you will have to drill an extra row of holes along the leading edge of the bumper cover...It uses the same holes in the rear that attach the bumper cover to the car.
I used the same body screws w/washers that are already used on the bumper cover with a u-nut inside instead of attaching it as a clip to the bumper.
I would only use the plastic push in rivets where you do not have access to the inside of the bumper cover, the center two holes
Old May 27, 2018 | 05:37 PM
guido7834's Avatar
guido7834
I installed mine using a rivet gun and rivets from Harbor Freight.
Old May 28, 2018 | 01:04 PM
Bob Beroza's Avatar
Bob Beroza
Thanks for the input...as always you guys are a world full of knowledge.
Old May 29, 2018 | 01:43 AM
nhisfan's Avatar
nhisfan
I ran mine over a year using just the original bumper cover bolts, in the rear.
Unless you're constantly running over 100 mph, the additional holes probably aren't necessary.
Maybe lay on a couple of strips of 3m tape along the front edge if want a little extra insurance, but I never had a problem...
Old May 29, 2018 | 12:17 PM
TEXHAWK0's Avatar
TEXHAWK0
True that it is not like it is going to fall off, but I think it will sag over time, and the lower it is, the more likely you will drag it on something. Also, I just wanted it to fit tight on the bumper on the leading edge to minimize the bugs, dirt, and debris that get between it and the bumper. adding tape will hold it, but increase the gap.
Old May 29, 2018 | 12:34 PM
Bob Beroza's Avatar
Bob Beroza
That an interesting idea...once I have the splitter in my hands I'll be able to play around with test fitment and method.
Old May 30, 2018 | 12:28 PM
3AD2the31's Avatar
3AD2the31
I took mine to a local body shop and they made it smooth and painted it Carbon Flash Metallic, $150. I also used rivets in the front row so if it did hit something it wouldn't roll under the car.
To Front Splitter
